ARDUINO UNO R3 PROBLEMS
Postby MOFUNGO » Thu Apr 19, 2012 8:14 pm
Trying to install Arduino uno R3, Have Windows 7 64 bit. Downloaded version 1.0 Software. Device Manager shows Arduino UnoR3 Com 3 and driver software upto date. Cannot find .Inf file, and cannot go any further. "L" led is always flashing. Downloaded files a number of times.
MOFUNGO
Re: ARDUINO UNO R3 PROBLEMS
Postby adafruit_support_bill » Fri Apr 20, 2012 4:48 am
When updating the driver file in Device Manager, navigate to the "Arduino-1.0/Drivers" folder. The inf file does not show up in the browse window, but it is there.
Postby MOFUNGO » Fri Apr 20, 2012 8:28 am
Thanks for quick response, I have done that many times. I pick Arduino-1.0 windows{1}\Arduino-1.0 drivers, I get message "The best driver software for your Device is already installed.
MOFUNGO
Postby adafruit_support_bill » Fri Apr 20, 2012 8:32 am
Uninstall it and try again.
Postby MOFUNGO » Fri Apr 20, 2012 8:47 am
I did and have same results, under properties (left click) ittell me "This device is working properly)
MOFUNGO
Postby adafruit_support_bill » Fri Apr 20, 2012 8:53 am
Are we past that stage now?
Postby MOFUNGO » Fri Apr 20, 2012 9:15 am
like I said originally, i don see see any signs of Adurino anywhere except in Device mangAm I missing something??
MOFUNGO
Postby adafruit_support_bill » Fri Apr 20, 2012 9:30 am
Open the IDE and select tools->serial port and select the COM port assigned by the device manager.
Postby MOFUNGO » Fri Apr 20, 2012 10:04 am
I'm sorry, but not sure what IDE is, and where it is located.
MOFUNGO
Postby adafruit_support_bill » Fri Apr 20, 2012 10:10 am
In the Arduino-1.0 folder there should be an application file called "Arduino". That is the Arduino IDE (Integrated Development Environment). Double click on it to run it.
Postby MOFUNGO » Fri Apr 20, 2012 10:34 am
I ran Arduino (file with arduino logo) and got Java virtual machine launcher saying" Can not find the main class processive,app.base" program will exit
MOFUNGO
Postby adafruit_support_bill » Fri Apr 20, 2012 10:42 am
This is from the Arduino Troubleshooting guide: http://arduino.cc/en/Guide/troubleshooting
What about the error "Could not find the main class."?
If you get this error when launching Arduino:
Java Virtual Machine Launcher: Could not find the main class. Program will exit.
make sure that you correctly extracted the contents of the Arduino .zip file - in particular that the lib directory is directly inside of the Arduino directory and contains the file pde.jar.
Postby MOFUNGO » Fri Apr 20, 2012 11:08 am
Let me very basic, as i am losing you. I open Arduino-1.0.windows[1], I now see a folder Arduino-1.0, I open that and see 10 items, Folders
_macosx, drivers, examples, hardwarw, than i see Arduino(logo), cygiconv-2.dll, cygwin1.dll, libusb0.dll, revisions, and rxtxserial.dll. that"s it
MOFUNGO
Postby adafruit_support_bill » Fri Apr 20, 2012 11:20 am
Don't worry, I'm not going anywhere. :)
So you do not see the "Lib" folder in there?
Download the Arduino 1.0 zip file from here and unpack it once more. You should have a "Lib" folder with the "pde" file inside it.
Postby MOFUNGO » Fri Apr 20, 2012 11:37 am
I downloaded as you asked and can see all folders now, can you help me with next step, to get Uno installed.
MOFUNGO
Next
Return to Arduino
Users browsing this forum: No registered users and 13 guests
New Products [103]
LEDs[109]
Cables[61]
