Brain machine (troubleshooting)
Postby Larryk » Fri Apr 20, 2012 12:58 pm
hello i purchased a brain machine (from the makershed) and i was very impressed with its user friendliness unfortunately after construction the right led didn't light up.
Larryk
Re: Brain machine (troubleshooting)
Postby adafruit_support_bill » Sat Apr 21, 2012 5:13 am
Post photos of the front & back of the board and we'll check your assembly.
Postby Larryk » Sun Apr 22, 2012 9:47 am
these are the picture (the orange and yellow led is working the blue and green led is not)
photo of back of the board
Larryk
Postby Larryk » Sun Apr 22, 2012 10:01 am
this is the front of the board
front of board.JPG (624.19 KiB) Viewed 1224 times
Larryk
Postby adafruit_support_bill » Sun Apr 22, 2012 10:28 am
If you could get a shot of the solder side with the same quality & lighting as the front view that would be great. There are a couple of suspicious areas (circled below).
You may have some 'cold joints' there. The solder joints should be smooth and shiny. Touch up anything that looks rough or frosted. There appears to be something bridging between one end of R4 and the nearby battery terminal. If this is solder, you need to remove it.
brain machine.png (701.72 KiB) Viewed 1222 times
Postby Larryk » Sun Apr 22, 2012 4:15 pm
hi thanks,
i touched up the joints by the blue and green wire and the circled , i waited till they got shiny,then wicked up.
there is no bridging between r4 and the battery (only from the angle the picture was taken)
i apologize, i took a shot in the same condition for the back of the board as the front but it didn't come out good.
Larryk
Postby adafruit_support_bill » Mon Apr 23, 2012 4:52 am
The other thing to check is the polarity of the LED. If it is connected in reverse, it will not light.
Postby Larryk » Fri May 04, 2012 2:47 pm
I am pretty sure i was careful to follow all directions in regards to the polarity of the led. what should i do now, should i reverse the blue and green wires?
Larryk
Postby adafruit_support_bill » Sun May 06, 2012 4:43 am
Yes. If that doesn't work. We can try replacing the LED.
Postby Larryk » Fri Jun 01, 2012 4:01 pm
IT WORKED!! thanks for the great customer support
Larryk
New Products [102]
LEDs[109]
Cables[60]
