Wave Shield Code Problem
Postby lbrinkworth » Tue Apr 24, 2012 2:48 pm
Hi, I used the code provided under "use it" for the wave shield, but when I tried to compile it, it said that "SDreader does not name a type." I'm pretty bad with code, and I just want to test the one provided. What's wrong with it?
lbrinkworth
Re: Wave Shield Code Problem
Postby adafruit_support_bill » Tue Apr 24, 2012 3:55 pm
A little more detail would be helpful:
Which example are you trying to run?
What version of the IDE?
Most likely, your SD library is not correctly installed.
http://www.ladyada.net/library/arduino/libraries.html
Return to Arduino Shields from Adafruit
Users browsing this forum: mibignistinly and 3 guests
New Products [103]
LEDs[109]
Cables[61]
