Adjustable 30W 110V soldering iron - XY-258 110V
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
Postby dmh » Sat Apr 21, 2012 11:24 pm
The Adjustable 30W 110V soldering iron - XY-258 110V was recommended to me but I was wondering what setting should I put it on when working with Arduino shields and projects etc....
Also I got some tinner but was wondering if there was some technique to using this stuff.
Mike
dmh
Re: Adjustable 30W 110V soldering iron - XY-258 110V
Postby adafruit_support_bill » Sun Apr 22, 2012 5:30 am
I don't have that particular iron, but I'd start with a medium/high setting. If you find that it is not keeping up, boost the setting a bit. Ideally, you should be able to bring most joints up to a temperature where it can melt the solder within a couple of seconds. (heavy joints such as power connector or switch lugs will take longer)
To use the tinner, just drag/roll the hot tip across it. It should come up nice and shiny.
Postby dmh » Sun Apr 22, 2012 8:10 pm
Thanks,
I was hoping to find something that would last a long time. Something that heats up quick and the tips last.
Any suggestions
Mike
dmh
Postby adafruit_support_bill » Mon Apr 23, 2012 5:15 am
It all depends on your budget. I would avoid anything less than 25W. The 30W adjustable iron is a nice step up from the typical entry-level iron. Together with a stand it makes a good basic soldering station. The next step up from that would be a temperature-controlled iron like the Hakko-888. Something like that or a Weller WES-51 should last pretty much forever. :)
Postby dmh » Mon Apr 23, 2012 5:43 pm
Thanks so much look forward to this purchase with adafruit.
dmh
Postby dmh » Tue Apr 24, 2012 9:13 pm
Oh, I almost forgot... Are there other tips available for the 30W iron?
dmh
Return to Tools Tools Tools
New Products [103]
LEDs[109]
Cables[61]
