Wave Shield and I2C Troubles
Postby KApple4 » Sun Apr 22, 2012 4:33 pm
I've been having some trouble utilizing I2C with the Wave Shield.
For my project: Arduino1 is the master sender, and Arduino2 houses the Wave shield as the slave receiver. Everything works fine with Arduino1 sending to Arduino2, as long as what Arduino2 is receiving only commands it to control an LED. For example, if k=2, LED1 is lit. However, once what is received commands a sound to be played on the wave shield, the information isn't received.
I've simplified the master sender code for testing, and it works with varying values of k, until it reaches 16 for the receiver code. I've figured out that it is definitely related to the wave shield, because I've varied values of k and the contents in each if loop of the receiver.
Below are the codes. Any suggestions, tips or tricks?
This is the master sender code:
#include <Wire.h>
#include <AFMotor.h> //takes from library
byte k = 0;
  Wire.begin(); // join i2c bus (address optional for master)
  Serial.begin(9600);           // start serial for output
  Serial.println("Master");
  randomSeed(analogRead(0));  //THIS HAS TO BE CHANGED to open input pin
void loop()
        //send information to Arduino 2 to play certain music file and light array of LEDs
k=16;
        Serial.println("ACHIEVEMENT");
        Wire.beginTransmission(4); // transmit to device #4
        Wire.write(k);              // sends one byte
        Wire.endTransmission();    // stop transmitting
        delay(2000); //time for motors to stop
Slave Receiver code:
#include <Wire.h>
//---------------WAVE SHEILD-------------------------
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
FatReader f;      // This holds the information for the file we're play
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
//----------------LEDS Initialize-----------------------
int LED7 = A0; //Scanning LED
int LED8 = A1; //Scanning LED
int LED9 = A2; //Scanning LED
int LED10 = A3; //Scanning LED
int LED1 = 0; //Target LED
int LED2 = 1; //Target LED
int LED3 = 6; //Target LED
int LED4 = 7; //Target LED
int LED5 = 8; //Target LED
int LED6 = 9; //Target LED
//------------------WAVE SHEILD debugging--------
int freeRam(void) { //says what free ram on SD card is
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
void sdErrorCheck(void){ //reports on errors
  if (!card.errorCode()) return;
  putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
//------------------SET UP--------------------------------
  byte i;
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  Serial.println("Slave");
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  pinMode(LED5, OUTPUT);
  pinMode(LED6, OUTPUT);
  pinMode(LED7, OUTPUT);
  pinMode(LED8, OUTPUT);
  pinMode(LED9, OUTPUT);
  pinMode(LED10, OUTPUT);
  //--//---WAVE SHEILD----
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(freeRam());      // if this is under 150 bytes it may spell trouble!
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Ready!");
  TCCR2A = 0;
  TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
void loop()
  delay(100);
//slavereceiver: For communication with Arduino 1
void receiveEvent(int howMany){
  Serial.println("working receive");
  int k = Wire.read();    // receive byte as an integer
  Serial.println(k);         // print the integer
  //Random: Randomly picks a target based on 6 lEDs
  if (k==1){
    Serial.println("L1");
    digitalWrite(LED1, HIGH);   // set the LED on
  if (k==2){
    Serial.println("L2");
    digitalWrite(LED2, HIGH);   // set the LED on
  if (k==3){
    Serial.println("L3");
    digitalWrite(LED3, HIGH);   // set the LED on
  if (k==4){
    Serial.println("L4");
    digitalWrite(LED4, HIGH);   // set the LED on
  if (k==5){
    Serial.println("L5");
    digitalWrite(LED5, HIGH);   // set the LED on
  if (k==6){
    Serial.println("L6");
    digitalWrite(LED6, HIGH);   // set the LED on
  //--------------ACHIEVEMENT-------------------------------------
  if (k==15){
    digitalWrite(LED1, LOW);    // set the LED off
    digitalWrite(LED2, LOW);    // set the LED off
    digitalWrite(LED3, LOW);    // set the LED off
    digitalWrite(LED4, LOW);    // set the LED off
    digitalWrite(LED5, LOW);    // set the LED off
    digitalWrite(LED6, LOW);    // set the LED off
    digitalWrite(LED7, LOW);    // set the LED off
    digitalWrite(LED8, LOW);    // set the LED off
    digitalWrite(LED9, LOW);    // set the LED off
    digitalWrite(LED10, LOW);    // set the LED off
    //light array?
    delay (3000);
  //------------SCANNING----------------------------------
  if (k == 7) {
    Serial.println("Scan1");
    digitalWrite(LED7, HIGH);   // set the LED on
  if (k == 8) {
  if (k == 9) {
    Serial.println("Scan2");
    digitalWrite(LED8, HIGH);   // set the LED on
  if (k == 10) {
  if (k == 11) {
    Serial.println("Scan3");
    digitalWrite(LED9, HIGH);   // set the LED on
  if (k == 12) {
  if (k == 13) {
    Serial.println("Scan4");
    digitalWrite(LED10, HIGH);   // set the LED on
  if (k == 14) {
  //---------------------SOUND-----------------------
  if (k==16){
    playcomplete("WELCOME.WAV");
    delay (500);
    delay (500);
    delay (500);
    delay (500);
    digitalWrite(LED7, HIGH);    // set the LED off
    digitalWrite(LED8, HIGH);    // set the LED off
    digitalWrite(LED9, HIGH);    // set the LED off
    digitalWrite(LED10, HIGH);    // set the LED off
    delay (2000);
} // end command receiving loop
//---------------WAVE SHEILD COMMANDS-----------------------------
void playcomplete(char *name) {
  // call our helper to find and play this name
  playfile(name);
  while (wave.isplaying) {
    // do nothing while its playing
  // now its done playing
void playfile(char *name) {
  // see if the wave object is currently doing something
  if (wave.isplaying) {// already playing something, so stop it!
    wave.stop(); // stop it
  // look in the root directory and open the file
  if (!f.open(root, name)) {
    putstring("Couldn't open file ");
    Serial.print(name);
    return;
  // OK read the file and turn it into a wave object
  if (!wave.create(f)) {
    putstring_nl("Not a valid WAV");
    return;
  // ok time to play! start playback
  wave.play();
Thanks in advance for the help!
K
KApple4
Re: Wave Shield and I2C Troubles
Postby KApple4 » Mon Apr 23, 2012 12:26 pm
I figured it out for anyone who might have the same problem.
You can't call a Library from receive event . Instead, I defined s as a volatile int, defined that in the receive event command, and commanded the sound through the loop for s.
Slave:
#include <Wire.h>
#include "WaveHC.h"
volatile int s = 0;
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
  byte i;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
  check_switches();
void loop()
  delay(100);
    if (s==16){
      Serial.println("WJDFSKJ");
    playcomplete("DUCK.WAV");
    delay (500);
    delay (500);
    delay (500);
    delay (500);
    delay (2000);
  if (s==17){
    delay (500);
    delay (500);
    delay (500);
    delay (500);
    delay (2000);
  if (k==1){
  if (k==2){
  if (k==3){
  if (k==4){
  if (k==5){
  if (k==6){
  if (k==15){
    //light array?
    delay (3000);
  if (k == 7) {
  if (k == 8) {
  if (k == 9) {
  if (k == 10) {
  if (k == 11) {
  if (k == 12) {
  if (k == 13) {
  if (k == 14) {
  if (k == 16) {
    s=16;   // set the LED off
    if (k == 17) {
    s=17;    // set the LED off
  playfile(name);
    Serial.print(name);
    return;
    return;
  wave.play();
KApple4
Postby erg144 » Wed Apr 25, 2012 11:39 am
Thanks for the fix. I was just getting ready to do the same thing and glad to know someone already blazed that trail.
I can tell you that you can not do I2C communication while in an interrupt service routine. While there - the interrupts are normally turned off so communication will not work.
erg144
Return to Arduino Shields from Adafruit
Users browsing this forum: dpaulc and 4 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
