advancedLEDbelt sketch works for 59 pixels but not 60+
Postby howsTricks » Thu Apr 26, 2012 11:15 pm
Playing with my LED strip continues! First off I have to say I really enjoy this thing, can't wait to get it fully setup but I'm having another issue. I'm working with the digital LED strip with 64 LEDs and it seems like the advancedLED belt sketch included in the library does not work with 60+ pixels. With 59 it works perfectly, cycling through all sort of neat patterns and presets but once I key in 60 or higher nothing lights at all. The other sketches (strandtest, longstrandtest and LEDbelt kit) work just fine with all 64 LEDs so I don't think it's a problem with my strip. I'm working with an old Arduino Duemilanove, maybe it's running into memory issues? I've tried running the original version of the code just in case there was some bug in the newer version but it results in the same issue. The coding in the advanced sketch is just a little beyond my ability to debug so I'm sure there's something I'm missing.
howsTricks
Re: advancedLEDbelt sketch works for 59 pixels but not 60+
Postby pburgess » Fri Apr 27, 2012 12:49 am
Hey there,
Yes, the advancedLEDbelt sketch is a total memory hog. Oink oink! If you're using an ATmega168-based Duemilanove, they I could definitely see this failing even on a 64 LED strip.
You might be able to free up juuuust enough memory by reducing the size of the 'fxVars' array -- it's declared a bit larger than is used by the sketch right now. Try changing line 60 to:
int  fxVars[3][10],
pburgess
Postby howsTricks » Fri Apr 27, 2012 8:27 pm
That did it! Thanks a bunch
howsTricks
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: mibignistinly and 7 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
