RGB Shield 714/716 Installed as Shield
Postby scottder » Tue May 01, 2012 11:33 am
I am curious with this installed as a shield how does one access the other available ports, do they pass through or are they still reachable under the shield. Sorry new to arduino.
Scott
scottder
Re: RGB Shield 714/716 Installed as Shield
Postby adafruit_support_bill » Tue May 01, 2012 11:49 am
Unused pins are 'passed through', but it is not so convenient to solder to the tops of the header pins. Other options would be a proto-shield build with stacking headers, or a screw-shield.
You can stack one of these between the Arduino and the RGB shield and have easy access to all pins.
Postby scottder » Tue May 01, 2012 11:55 am
Hmm ok, may be easier to external mount then ( looking at this for a garduino type project. So likely I will put this in a enclosure as well. Thanks for thew quick response!
Scott
scottder
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 3 guests
New Products [102]
LEDs[109]
Cables[60]
cron
