2.8" touch screen-unknown driver chip 0
Postby walterstx » Wed May 02, 2012 10:51 am
I have the 2.8' touch screen connected to an Arduino uno. When I run the "GraphTest" program I get a " unknown driver chip 0" message. I have checked the wiring several times. I have checked continuity from board to board. I have also tried commenting out the "Shield Pinout" line in the header file. Any suggestions?
walterstx
Re: 2.8" touch screen-unknown driver chip 0
Postby adafruit_support_bill » Wed May 02, 2012 12:02 pm
Do you see the "Using Adafruit 2.8 inch TFT Breakout Pinout" in the serial output?.
If you post photos showing all your connections we'll take a look.
Postby walterstx » Wed May 02, 2012 1:05 pm
This is the header file "//#define USE_ADAFRUIT_SHIELD_PINOUT ".As you can see it is commented out. This is the Serial Monitor :
8 Bit LCD test!
Using Adafruit 2.8 inch TFT Arduino Shield Pinout
Unknown driver chip 0
I searched my computer for Adafruit_TFTLCD.h and found three. Two were in my documents file. I changed those to comment out "//#define USE_ADAFRUIT_SHIELD_PINOUT ". Still got the same results.
What should I try next?
Thanks.
walterstx
Postby walterstx » Wed May 02, 2012 2:21 pm
Regardless of wiring if the "//#define USE_ADAFRUIT_SHIELD_PINOUT" is commented out should not the correct "PINOUT" message be displayed?
walterstx
Postby adafruit_support_bill » Wed May 02, 2012 4:43 pm
Somehow it is trying to use the shield pinout. What folders were the different copies of the file in? If you open "Files->Preferences", you can select "verbose" output for compiliation. It will print out a lot of stuff when you compile, but in there will be the paths for all the files it included. If you post that up we'll take a look through. (Use the "Code" button above the edit box and paste the output between the code tags.)
Postby walterstx » Wed May 02, 2012 5:31 pm
How do you select the output?
walterstx
Postby walterstx » Wed May 02, 2012 5:50 pm
I figured out how to copy the output, I think.
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\graphicstest_verb.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\graphicstest_verb.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\utility C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\glcdfont.c -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\Adafruit_GFX\glcdfont.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\utility C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\Adafruit_GFX.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\Adafruit_GFX\Adafruit_GFX.cpp.o
In file included from C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\Adafruit_GFX.cpp:18:
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\/glcdfont.c:9: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD\utility C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\adafruit_TFTLCD\Adafruit_TFTLCD.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:270: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:322: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::drawFastLine(int16_t, int16_t, int16_t, uint16_t, uint8_t)':
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:127: warning: 'newentrymod' may be used uninitialized in this function
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WInterrupts.c -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\WInterrupts.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring.c -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_analog.c -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring_analog.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_digital.c -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring_digital.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_pulse.c -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring_pulse.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_shift.c -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring_shift.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\CDC.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\CDC.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\HardwareSerial.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\HardwareSerial.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\HID.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\HID.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\IPAddress.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\IPAddress.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\main.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\main.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\new.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\new.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Print.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\Print.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Stream.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\Stream.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Tone.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\Tone.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Tone.cpp:108: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\USBCore.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\USBCore.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WMath.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\WMath.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WString.cpp -oC:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\WString.cpp.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\WInterrupts.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring_analog.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring_digital.c.o
C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build7597677892382661053.tmp\wiring_pulse.c.o
walterstx
Postby adafruit_support_bill » Wed May 02, 2012 7:28 pm
Looks like you have adafruit_TFTLCD installed in the Libraries folder under the Arduino-1.0 install folder. This is not the right location.
You should have a folder called simply "Arduino" in your user area. The library should be installed in a "Libraries" folder under that. Delete all other copies of the library!
For details on installing libraries, check the tutorial: http://www.ladyada.net/library/arduino/libraries.html
Postby walterstx » Thu May 03, 2012 10:46 am
I think that this is now the way you described. I still get the same results.
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX\utility C:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX\glcdfont.c -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Adafruit_GFX\glcdfont.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX\utility C:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX\Adafruit_GFX.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Adafruit_GFX\Adafruit_GFX.cpp.o
In file included from C:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX\Adafruit_GFX.cpp:18:
C:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX\/glcdfont.c:9: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard -IC:\Users\Steve\Desktop\Arduino\libraries\Adafruit_GFX -IC:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD\utility C:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\adafruit_TFTLCD\Adafruit_TFTLCD.cpp.o
C:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:270: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:322: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::drawFastLine(int16_t, int16_t, int16_t, uint16_t, uint8_t)':
C:\Users\Steve\Desktop\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:127: warning: 'newentrymod' may be used uninitialized in this function
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\WInterrupts.c -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\WInterrupts.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\wiring.c -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\wiring_analog.c -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_analog.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\wiring_digital.c -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_digital.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\wiring_pulse.c -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_pulse.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\wiring_shift.c -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_shift.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\CDC.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\CDC.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\HardwareSerial.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\HID.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\HID.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\IPAddress.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\IPAddress.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\main.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\main.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\new.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\new.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\Print.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Print.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\Stream.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Stream.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\Tone.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Tone.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\Tone.cpp:108: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\USBCore.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\USBCore.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\WMath.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\WMath.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino -IC:\Users\Steve\Desktop\Arduino\hardware\arduino\variants\standard C:\Users\Steve\Desktop\Arduino\hardware\arduino\cores\arduino\WString.cpp -oC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\WString.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\WInterrupts.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_analog.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_digital.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_pulse.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\wiring_shift.c.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\CDC.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\HardwareSerial.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\HID.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\IPAddress.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\main.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\new.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Print.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Stream.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Tone.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\USBCore.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\WMath.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\WString.cpp.o
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-gcc -Os -Wl,--gc-sections -mmcu=atmega328p -o C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp.o C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Adafruit_GFX\glcdfont.c.o C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\Adafruit_GFX\Adafruit_GFX.cpp.o C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\adafruit_TFTLCD\Adafruit_TFTLCD.cpp.o C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\core.a -LC:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp -lm
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp.eep
C:\Users\Steve\Desktop\Arduino\hardware\tools\avr\bin\avr-objcopy -O ihex -R .eeprom C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build5253495855676811006.tmp\graphicstest.cpp.hex
Binary sketch size: 17830 bytes (of a 32256 byte maximum)
walterstx
Postby adafruit_support_bill » Thu May 03, 2012 11:20 am
It looks like you moved your entire Arduino-1.0 install to your "C:\Users\Steve\Desktop\Arduino\hardware\arduino" folder. I guess I wasn't quite clear on the distinction between the "Arduino-1.0" folder and the "Arduino" folder:
You should install the Arduino-1.0 install in its own folder by that name on your machine as you did before "C:\Users\Steve\Desktop\arduino-1.0-windows\arduino-1.0". This will contain the IDE and all the standard libraries.
When you run the IDE, it will create the "C:\Users\Steve\Desktop\Arduino\hardware\arduino" folder. This is your "sketchbook" folder which will contain all of your sketches, as well a "Libraries" folder for other libraries you download (such as the TFT_LCD library).
The reason for this separation between the "Arduino-1.0" install folder and your "Arduino" sketchbook folder is so that future updates of the Arduino IDE will not over-write all your sketches and downloaded libraries.
The IDE will search both locations for libraries. So you have to be careful not to have multiple copies of the same library, because you can't be sure which one the compiler will try to use.
Postby walterstx » Thu May 03, 2012 3:43 pm
I think it is geting close. Now when it is compiled I get the error "Adafruit_TFTLCD does not name a type".
walterstx
Postby adafruit_support_bill » Thu May 03, 2012 4:29 pm
That usually means that it didn't find the library. If you installed (or moved) the library while the IDE was open, you need to close it (if you have multiple IDE windows open, be sure to close all of them) then open it again.
Postby walterstx » Thu May 03, 2012 6:26 pm
The adafruit_TFTLCD looks to be in the right file path.
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\utility C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\glcdfont.c -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Adafruit_GFX\glcdfont.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\utility C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\Adafruit_GFX.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Adafruit_GFX\Adafruit_GFX.cpp.o
In file included from C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\Adafruit_GFX.cpp:18:
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\/glcdfont.c:9: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\utility C:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\adafruit_TFTLCD\Adafruit_TFTLCD.cpp.o
C:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:270: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:322: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::drawFastLine(int16_t, int16_t, int16_t, uint16_t, uint8_t)':
C:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp:127: warning: 'newentrymod' may be used uninitialized in this function
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WInterrupts.c -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\WInterrupts.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring.c -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_analog.c -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_analog.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_digital.c -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_digital.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_pulse.c -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_pulse.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_shift.c -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_shift.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\CDC.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\CDC.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\HardwareSerial.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\HardwareSerial.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\HID.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\HID.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\IPAddress.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\IPAddress.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\main.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\main.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\new.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\new.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Print.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Print.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Stream.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Stream.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Tone.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Tone.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Tone.cpp:108: warning: only initialized variables can be placed into program memory area
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\USBCore.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\USBCore.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WMath.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\WMath.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WString.cpp -oC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\WString.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\WInterrupts.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_analog.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_digital.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_pulse.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\wiring_shift.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\CDC.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\HardwareSerial.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\HID.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\IPAddress.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\main.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\new.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Print.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Stream.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Tone.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\USBCore.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\WMath.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\WString.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -Os -Wl,--gc-sections -mmcu=atmega328p -o C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp.o C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Adafruit_GFX\glcdfont.c.o C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\Adafruit_GFX\Adafruit_GFX.cpp.o C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\adafruit_TFTLCD\Adafruit_TFTLCD.cpp.o C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\core.a -LC:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp -lm
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp.eep
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-objcopy -O ihex -R .eeprom C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build656744846264497175.tmp\graphicstest.cpp.hex
Binary sketch size: 16972 bytes (of a 32256 byte maximum)
walterstx
Postby adafruit_support_bill » Thu May 03, 2012 7:15 pm
According to the last line, it looks like it compiled successfully. What do you see when you run it now?
Postby walterstx » Fri May 04, 2012 12:58 pm
I get this when I run the program.
8 Bit LCD test!
Does this file "Adafruit_GFX.h" go in the Main Ardurino/Libraries file or the Sketchbook libraries file?
Here is the output:
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\utility C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\glcdfont.c -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Adafruit_GFX\glcdfont.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\utility C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX\Adafruit_GFX.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Adafruit_GFX\Adafruit_GFX.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\libraries\Adafruit_GFX -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD -IC:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\utility C:\Users\Steve\Documents\Arduino\libraries\adafruit_TFTLCD\Adafruit_TFTLCD.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\adafruit_TFTLCD\Adafruit_TFTLCD.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WInterrupts.c -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\WInterrupts.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring.c -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_analog.c -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_analog.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_digital.c -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_digital.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_pulse.c -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_pulse.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\wiring_shift.c -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_shift.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\CDC.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\CDC.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\HardwareSerial.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\HardwareSerial.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\HID.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\HID.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\IPAddress.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\IPAddress.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\main.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\main.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\new.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\new.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Print.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Print.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Stream.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Stream.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\Tone.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Tone.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\USBCore.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\USBCore.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WMath.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\WMath.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino -IC:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\variants\standard C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\arduino\cores\arduino\WString.cpp -oC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\WString.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\WInterrupts.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_analog.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_digital.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_pulse.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\wiring_shift.c.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\CDC.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\HardwareSerial.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\HID.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\IPAddress.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\main.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\new.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Print.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Stream.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Tone.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\USBCore.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\WMath.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-ar rcs C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\WString.cpp.o
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-gcc -Os -Wl,--gc-sections -mmcu=atmega328p -o C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp.o C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Adafruit_GFX\glcdfont.c.o C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\Adafruit_GFX\Adafruit_GFX.cpp.o C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\adafruit_TFTLCD\Adafruit_TFTLCD.cpp.o C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\core.a -LC:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp -lm
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp.eep
C:\Users\Steve\Downloads\arduino-1.0-windows\arduino-1.0\hardware\tools\avr\bin\avr-objcopy -O ihex -R .eeprom C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp.elf C:\Users\Steve\AppData\Local\Temp\build8950848837838348608.tmp\graphicstest.cpp.hex
walterstx
Next
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
