just another1 with RGB-LCD Problems
Postby c-bob » Thu May 03, 2012 12:16 pm
Hello fruities!
I'm new to *duino and everything related with embedded systems, but not new to programming.
My Problem: I've got an RGB LCD Shield Kit (#714) from watterott and assembled all parts. Now I want to try to use it by the provided example but nothing but the reset-button works.
If I maximize the contrast potentiometer I can see on the first line every dot is blacked out and the 2nd line is clean and there is no backlight.
Can I test the backlight without connection to my arduino mega 2560? BTW: which format are the *.brd and *sch files from gtihub? Tried gEDA and KiCAD (debian sid) but that doesnt work.
-c-
c-bob
Re: just another1 with RGB-LCD Problems
Postby adafruit » Thu May 03, 2012 12:17 pm
Are you using an R3 Mega? It is only plug-compatible with R3 Megas
Postby c-bob » Thu May 03, 2012 3:58 pm
Hm, sorry, I dont know...I can not see anything on the board - only arduino mega 2560. How can I find it out?
PS: oops, sorry - on the arduino.cc page I've seen, that Imust have a Version before the R3... So what can I do?!
c-bob
Postby c-bob » Fri May 04, 2012 12:40 am
Hm, I dont have eagle so I cannot open then schematics - darn!
And gEDA crashes by openeing the files :(
(BTW: I'm on linux)
c-bob
Postby c-bob » Fri May 04, 2012 3:07 am
Oh, okay, I see - on Mega < R3 the i2c pins are 20 and 21 so I have to rewire only the 2 overlaping pins to the 20 and 21? Or must the pins A4 and A5 be cut?
c-bob
Re: just another1 with RGB-LCD Problems [SOLVED]
Postby c-bob » Fri May 04, 2012 3:36 am
Okay guys, I got it. Rewireing is the Key - the upper left pins of the RGB-LCD-Shield has to be connected to pins 20 and 21 and then it works.
But another question: in example there was the following line:
Serial.print("Took "); ... (no copy/paste possible)..bla.. (" ms");
Why does this appear on LCD? Isnt lcd.print!=serial.print?
c-bob
Postby c-bob » Mon May 07, 2012 9:31 am
c-bob
Postby c-bob » Tue May 08, 2012 2:35 am
Jep, thats it! - maybe another pin-out problem on the mega2560? You know: the communication pins (0 and 1 of the first UART) are the first 2 pins connected to the shield?!
EDIT: But okay, I see: the UAT -Pins are not connected...
c-bob
Postby adafruit_support_bill » Tue May 08, 2012 5:04 am
I'll see if I can track down an older Mega and give it a try.
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: mibignistinly and 2 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
