DS1307 Date and Time Will Not Reset
Postby Maxxim » Fri May 04, 2012 8:58 am
I purchased and assembled the “DS1307 Real Time Clock breakout board kit”. The kit worked beautifully for about a week and then it started returning a very strange time and date (see exhibit #1). I pulled the battery for about 1 min hoping that it would return to the beginning time and date but instead it is returning the time and date in exhibit #2. It is also no longer incrementing time. Does anyone have a clue how to reset the clock?
Exhibit #1
2165/165/165 165:165:85
since 1970 = 1396050385s = 16157d
now + 7d + 30s: 2014/4/4 23:46:55
Exhibit #2 (notice that the time is not incrementing).
RTC is NOT running!
I did un-remark the time setting command "RTC.adjust(DateTime(__DATE__, __TIME__));" to set the clock to compile time. No luck.
Code used to set the clock:
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 RTC;
void setup () {
    Serial.begin(57600);
    Wire.begin();
    RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    //RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
    DateTime now = RTC.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.println();
    Serial.print(" since 1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days and 30 seconds into the future
    DateTime future (now.unixtime() + 7 * 86400L + 30);
    Serial.print(" now + 7d + 30s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    Serial.println();
    Serial.println();
    delay(3000);
Maxxim
Re: DS1307 Date and Time Will Not Reset
Postby adafruit_support_bill » Fri May 04, 2012 10:08 am
Post photos of your soldering and connections. This is a symptom of a bad connection somewhere.
Postby Maxxim » Fri May 04, 2012 1:37 pm
I have two pictures ready. One of the bottom and one of the top. I can't upload them here (invalid file error) so the links below will take you to them.
https://picasaweb.google.com/1057769545 ... directlink
This was my first soldering job but it did work for about 1 week before the problem developed.
Thanks in advance for your help.
John
Maxxim
Postby adafruit_support_bill » Fri May 04, 2012 1:44 pm
The 5v and SDA pins on top need a bit more solder. The back-side photo is a little too dark to see well, but look closely at the joints and re-touch any that are not smooth and shiny. A 'frosted' appearance indicates a cold joint and they can become intermittent over time.
Also, did you remember to put a blob of solder under the battery clip? It is needed to assure good contact with the battery.
Postby Maxxim » Fri May 04, 2012 1:53 pm
I will touch them up and take new pictures and post them. I did add the solder to the battery area as well. I will include a picture of that as well.
Maxxim
Postby buckidge » Fri Oct 12, 2012 11:50 am
I second this as a solution to the problem. I just got done re-soldering my connections and this fixed the exact same problem as the original post described.
buckidge
Return to Microcontrollers
Users browsing this forum: No registered users and 7 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
