Does Miniature WiFi support RFMON/Monitor mode?
Postby PJman » Mon May 07, 2012 3:23 pm
I want build a compact standalone wifi sniffer with my new Beaglebone. I came across the new Miniature WiFi module from adafruit and wanted to ask, does anyone know if it supports RFMON/Monitor mode? Has anyone tried using it with Aircrack-ng?
Also, any recommendations on which USB WiFi module works best with Beaglebone + Aircrack-ng?
PJman
Re: Does Miniature WiFi support RFMON/Monitor mode?
Postby adafruit » Mon May 07, 2012 4:23 pm
You'll need to figure out which chipsets support it, this is an RTL8192. It works great with the Bone but not sure what RFMON or Aircrack is
Postby PJman » Mon May 07, 2012 4:50 pm
adafruit, thanks for the quick response! I guess the best way would be to test it out.
Do you have any specs on the received signal strength (in db?).
PJman
Postby adafruit » Mon May 07, 2012 7:30 pm
Everything we know is in the technical tab, we'll try to get an external-antenna version that works, but unfortunately we found that not all USB adapters were friendly with the Bone, this one was!
Users browsing this forum: mibignistinly, VeleBookSot and 1 guest
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
