Need help programming Atmega328-AU with avrdude and USBtinyISP!
Postby jinx6672 » Fri May 11, 2012 2:09 pm
I need help programming Atmega328-AU with avrdude and USBtinyISP!
I have tried using the Arduino IDE but I couldn't find the pins_arduino.h file for the 328P-AU. Now I am trying to use avrdude and it doesn't reference the 328P-AU either. what files do I need or create to make this happen.
jinx6672
Re: Need help programming Atmega328-AU with avrdude and USBtinyISP!
Postby adafruit_support_rick » Fri May 11, 2012 2:27 pm
The 328P pinout is the same as the 328, which is what is used in the arduino. You shouldn't have to do anything special.
Postby BillO » Mon May 14, 2012 8:36 am
The 328 has a different device ID than the 328P. Either create a section in avrdude.conf for the 328, identical to the section for the 328P, except using the correct device ID, or use the -F switch on the avrdue command line like this;
avrdude -pm328p -cusbtiny -Ulock:w:0x0F:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m -Uefuse:w:0x05:m -V -Uflash:w:ATmegaBOOT_168_atmega328.hex:i -u -F
Which will program the chip with the Arduino Duemilanove bootloader. Just change the "ATMegaBOOT_168_stmega328.hex" to the name of the file you want to use.
BillO
Return to USBtinyISP
Users browsing this forum: MSN [Bot] and 2 guests
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
