How to solder flexible connector on 1.8 TFT?
Chat about pick and place machines, reflow ovens, assembly techniques and other SMT tips & trix
Postby philipm » Sat May 12, 2012 9:48 am
Anyone soldered the 1.8 TFT screen by hand yet? I see it has a flexible connector which interfaces to pads on the PCB. I understand that the factory way to do this is with a "hot bar". Is there a way to do it with basic hand tools?
philipm
Re: How to solder flexible connector on 1.8 TFT?
Postby philipm » Sat May 12, 2012 10:46 am
LOL!
Is there a way of doing it? How much heat will the flexible substrate take? I see the pads are two sided with vias. Can I simply tin the contacts on the PCB, place the connector on top and heat from the top?
philipm
Postby adafruit_support_bill » Sat May 12, 2012 12:47 pm
That should work. Make sure everything is nice and clean so the solder will wet the pads as soon as it flows. The substrate will take a bit of heat, but the traces will likely lift first.
Postby ktownsend » Thu May 17, 2012 6:25 pm
Here's how I did it. Get some thin no clean solder wire (I use 0.4mm in this video) and some magnification. It's important to have a decent sized tip for maximum heat transfer, and I tape the FPC down flat with high-temp (Kapton) tape to hold it in place:
http://www.youtube.com/watch?v=R698z9QaypY&feature=plcp
ktownsend
Postby philipm » Fri May 18, 2012 7:57 am
Very nicely done! Thanks for sharing, great to see how it works and should look in practice.
philipm
Postby ktownsend » Fri May 18, 2012 4:48 pm
I know ladyada and the Adafruit team came up with a different solution of putting some solder paste down and then pushing it towards/onto the FPC, and it seems to work well (though being half-blind I'm still hopeless without at least 5x magnification). The video is just what I've gotten used to but I use a microscope which tends to give your hand magical powers. With a decent sized tip and good solder wire, though, you should be able to reproduce the video above. 0.4mm is kind of hard to find sometimes (Digikey doesn't seem to have anything great ... I get my own in Japan, "goot SF-A0404" lead free), but that's what I use 90% of the time myself.
Kevin
ktownsend
Postby eliminster » Tue Jun 05, 2012 10:35 pm
I have an issue...I lifted the pad on 14. I was replacing the screen and while lifting the old one off 14 tore from the board. According to the spec sheet, 1 and 14 are NC. Is there anything I can do to recover from this? Perhaps if you sell a board separately since I have a brand new 1.8" TFT? Suggestions?
"Accept the things to which fate binds you, and love the people with whom fate brings you together, but do so with all your heart."
- Marcus Aurelius
eliminster
Postby adafruit_support_bill » Wed Jun 06, 2012 5:14 am
"NC" is "No Connection" so it shouldn't be a problem. You picked a good one to lift :D
Return to SMT (Surface Mount Tech)
Users browsing this forum: No registered users and 3 guests
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
