power mod C7 C8
power mod C7 C8
Postby evostars » Sun May 13, 2012 7:46 pm
Hi everybody!
I was comparing the x0xb0x powersection to the original powersection of the TB303 and found 2 condensators that are bigger in the x0xb0x.
They influence the VCF , VCA and the VCO.
bigger Condensators mean stable voltage... but I guess, I dont want that!
Maybe I need the fluctuations for my analog ears ;)
So...
C7 is 100uF 25V in the x0xb0x, but in the tb303 it's, 10uF 16V
C8 is 100uF 25V in the x0xb0x but in the tb303 it's 47uF 16V
Did anybody try bmod this before?
I'm hoping for more unstable analog sound
C69 and c70 are C7 and C8
power section.png (32.03 KiB) Viewed 2737 times
evostars
Re: power mod C7 C8
Postby guest » Mon May 14, 2012 12:05 am
interesting
let us know how it goes
im suspecting that c8 wont make much difference
i think its been tried before to investigate the warble
but didnt have much effect
c7 is likely to have more of an effect
but the zener in the x0x is way more stable
so it probably wont be bothered by any extra fluctuations
ultimately the x0x powersupply is pretty different
so it will be tough to get it mimic the 303
guest
Re: power mod C7 C8
Postby evostars » Mon May 14, 2012 4:56 am
Yeah the zener. I looked into that. Thats hard to fix... Maybe make the 2200 uF smaller also...
Have there been other solutions for the zener?
evostars
Re: power mod C7 C8
Postby evostars » Mon May 14, 2012 6:19 am
by the way, its not a zener, its a schottky 6,4V
evostars
Re: power mod C7 C8
Postby evostars » Mon May 14, 2012 6:47 am
vishay has one. TZX6V2E (6.4V schottky)
but to get it... is a different story.
at least, d44 d45 d46 and d47 could be removed, and replaced with wire..
evostars
Re: power mod C7 C8
Postby guest » Mon May 14, 2012 1:18 pm
its a 6.4v zener
with .005%/C temperature coefficient
youd have to put the rest of the resistors in
to get it to work
probably not worth it
i think the most important difference
between the x0x and 303 powersupply
is the switch supply on the 303
it produced a much lower voltage of around 15v
with a higher output impedance
guest
Re: power mod C7 C8
Postby evostars » Mon May 14, 2012 3:51 pm
guest wrote:its a 6.4v zener
to get it to work
I found a 6.2 V zener wich should work in combi with the resistors.
Shouldn't be to hard.
What do you mean with the switch supply?
evostars
Re: power mod C7 C8
Postby guest » Mon May 14, 2012 4:17 pm
the x0x powersupply is linear
it just rectifies the incoming AC
and then sends it to the opamp for regulation
the 303 on the other hand
takes in a lower voltage
and then steps it up to 15v or so
using a transformer and an oscillator circuit
guest
Re: power mod C7 C8
Postby evostars » Mon May 14, 2012 4:23 pm
guest wrote:the x0x powersupply is linear
Ah ok. Yes i saw the big differences.
I dont understand why the x0xb0x has this stable supply thats so different than the 303...
Anyway, i havent build it yet, so i like to look for mods before i have to di the work twice...
evostars
Re: power mod C7 C8
Postby evostars » Fri May 25, 2012 6:50 pm
I cant find information on modding the power supply, hasn't anybody tried it? Makes me motivated to score a zener and try it out myself.
I did find some info, but not enough...
Guess i also need to lower the dc psupply of the opamp itself...
evostars
Re: power mod C7 C8
Postby antto » Sat May 26, 2012 2:05 am
did you check the x0x wiki?
there was something about lowering the value of the first few resistors (which are in the power supply)
other than that, i don't know..
..:: c0nb0x v1.00 ::.. viewtopic.php?f=7&t=29282 (new control app - win/osx)
VCO Tuning: viewtopic.php?f=12&t=24759 (do it the EASY way)
antto
Re: power mod C7 C8
Postby evostars » Sat May 26, 2012 3:37 am
antto wrote:did you check the x0x wiki?
Yes, checked. That should lower the ps to the opamp
evostars
Re: power mod C7 C8
Postby evostars » Sat May 26, 2012 6:53 pm
I think I'm going to replace IC22 for a 6.4V zener (or a voltage near that).
Together with a resistor between pin 6 and 7 of IC23, and a trace cut, and some wires, and reduce C8 to 47uF.
The PS will be more like the TR303.
I could use the 2K trimpot, and change R4 according, to get 5.333V
A 6.4V schottky would even be better (less noise I guess, maybe put in a 0,1uF bypass cap over the zener) but its harder to buy...
I think I'm gonna try this.
If anybody got comments, please post!
edit: forgot C7... also change it to 10uF/16V
front printmod.jpg (191.51 KiB) Viewed 2529 times
evostars
Re: power mod C7 C8
Postby antto » Sun May 27, 2012 5:10 am
it would a good idea (if it's not too late) to record a pattern before the modification, and the re-record the same pattern after the modification
this way we can see/hear what exactly happened
antto
Re: power mod C7 C8
Postby evostars » Sun May 27, 2012 5:19 am
antto wrote:it would a good idea (if it's not too late) to record a pattern before the modification, and the re-record the same pattern after the modification
Yes, that is a good plan.
A bit more work though.
Haven't started building yet :-D
I think ill use 2 zeners in series that ad up to 6.3V
evostars
Next
Return to x0xm0dz
New Products [102]
LEDs[109]
Cables[60]
