Problem displaying bitmaps and shapes on the 1.8" TFT Screen
Postby FRAC » Thu May 17, 2012 10:39 am
Hi all,
I recently bought the 1.8" TFT Screen but I can't display any shapes or bitmaps on it. I mean, I think I wired the cables correctly indeed when I test text display it works fine but... only a few milli-seconds!!
After that delay the screen returns opaque and nothing more will happen on it (despite the program is still running: on the serial port I can still diplay informations).
The problem is neither due to over-memorie capacity (I check that on the console when I load the program on the arduino card) nor to the Micro SD card I used externally (the serial port notice me that the SD card works fine).
Concretely this what happen when I run the spitfbitmat example on the arduino:
On the screen I see a few moments a colored pixel fog and then nothing happenned...
On the serial port I see this:
Initializing SD card...OK!
Loading image 'parrot.bmp'
File size: 61496
Image Offset: 54
Header size: 40
Bit Depth: 24
Image size: 128x160
Loaded in 1214 ms
This is my schematic http://scott-bot.com/wp-content/uploads ... ematic.png
Any idea where could be the problem?
Ps- in the Tools-> programmer menu I choose AVR ISP can it be source of the problem?
FRAC
Re: Problem displaying bitmaps and shapes on the 1.8" TFT Screen
Postby adafruit_support_bill » Thu May 17, 2012 11:22 am
Do you have a photo of your actual connections? I don't see anything corresponding to the backlight pin on your schematic.
Postby FRAC » Thu May 17, 2012 12:13 pm
This a picture I take from my schematic:
https://twitpic.com/9m3nnq/full
Hope it will be clear
The "..." indicate that the pin are not plugged
By the way thanks for your help :)
FRAC
Postby adafruit_support_bill » Thu May 17, 2012 1:08 pm
Your wiring does not match the example in the tutorial. You have Tx tied to the Reset pin. Anytime you send anything on the serial port it will reset the LCD.
D/C is connected to pin 4 instead of 9. And there is some other yellow wire connected there as well.
Postby FRAC » Fri May 18, 2012 9:57 am
Ok I see what you mean for the reset problem. This my code which is supposed to go with the schematic above:
int dataPin = 3;
int clockPin = 2;
#define sclk 13
#define mosi 11
#define rst 1
#define cs 10 // <=> TFT_CS
#define dc 4
#define SD_CS 8
  pinMode(7, OUTPUT); // LED 1
  pinMode(6, OUTPUT); // LED 2
  pinMode(9, INPUT); // BUTTON 1
  pinMode(5, INPUT); // BUTTON 2
  pinMode(10, OUTPUT); // CS
  digitalWrite(cs, HIGH);
  digitalWrite(7, LOW);
So if I understand well, the only things I have to do are to disconnect the rst pin on the screen and plugged it into the Vcc and disconnected the Tx pin on the arduino. But which port should I specify for the rst pin in the code?
FRAC
Postby adafruit_support_bill » Fri May 18, 2012 10:27 am
We recommend that you get it working first with the tutorial configuration, then change one thing at a time to simplify debugging.
If you are not going to use the reset function, you can specify an invalid pin number like -1. It is better to connect the pin to the Arduino reset instead of VCC. That way the lcd will reset when the Arduino does.
Postby FRAC » Fri May 18, 2012 12:38 pm
Ok I will try that thanks for the support :)
FRAC
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
