Environment is WIN7
Are you on a 32 or 64 bit system?
In C:/Windows/inf, there should be a file called "setupapi.dev.log". The last section should show a record of your driver install attempts and may contain some useful information for diagnosing the problem.
Post the last few hundred lines (use the "code" button above the edit window and paste the text between the tabs.)
