Actual MCU in Arduino NANO
Postby customdev » Tue May 22, 2012 10:28 pm
Can anyone tell me what is the MCU on the Arduino NANO 3, is it an ATMEGA328p-au or an ATMEGA328-au?
customdev
Re: Actual MCU in Arduino NANO
Postby adafruit_support_rick » Wed May 23, 2012 8:40 am
The schematic is here, but they didn't update the label on the CPU. Gravitech's page doesn't day anything about a 328P
Postby westfw » Thu May 24, 2012 12:21 am
It pretty much has to be a 328p. The compiler shipped with the Arduino IDE (windows/mac) doesn't support the 328.
It could be a 328 with a lying bootloader (which is sort-of the recommended way of using a non-P 328 on Arduinos.)
Um. Have you found an actual difference between 328 and 328p that is relevant to ... anything? My (idle, uninformed) speculation has been that 328s are 328Ps that failed to meet the low-current specifications.
westfw
Postby adafruit_support_rick » Thu May 24, 2012 9:27 am
westfw wrote:My (idle, uninformed) speculation has been that 328s are 328Ps that failed to meet the low-current specifications.
Tch! What a nasty, cynical idea. But I'm sure you're absolutely right. That's why the versions of CPUs with higher clock rates always made me a little nervous - just how close to edge are they really running?
Postby westfw » Fri May 25, 2012 1:08 am
(it would raise interesting questions about when and how the signature bytes are written in the chip. The 328 and 328p have different signatures, so if my cynical theory is true, they can write the signature rather late in the manufacturing cycle. On the other hand, the 644 and 644a have the SAME signature even thought they're rather drastically different (644 only has one UART!), which implies that they can't easily change signatures.)
westfw
Postby adafruit_support_rick » Fri May 25, 2012 3:10 pm
Maybe the 644's are 644a's with one bad UART :wink:
Return to Arduino
Users browsing this forum: No registered users and 5 guests
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
