Initializing SD card...LOGG!
// #include <RTClib.h>// RTC_DS1307 RTC; // define the Real Time Clock object
// connect to RTC
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
*/ // DateTime now; // fetch the time
// now = RTC.now();
Serial.println(brain.readErrors());
Serial.println(brain.readCSV());ERROR: Checksum
200,0,0,2076078,112614,60749,194459,149189,52289,43309,33957
// #include <Wire.h> #include <SD.h>
#include <Wire.h>
#include <RTClib.h>
#define RTC_INCLUDE 1
#include <MemoryFree.h>
#include <Brain.h>
// #include <SoftwareSerial.h>
// A simple data logger for the Arduino analog pins
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL 1000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 2
#define greenLEDpin 3
// The analog pins that connect to the sensors
#define photocellPin 0 // analog 0
#define tempPin 1 // analog 1
#define BANDGAPREF 14 // special indicator that we want to measure the bandgap
#define aref_voltage 3.3 // we tie 3.3V to ARef and measure it with a multimeter!
#define bandgap_voltage 1.1 // this is not super guaranteed but its not -too- off
#if RTC_INCLUDE
#endif
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
// Create a SoftwareSerial connection, TX on pin 4, and RX on pin 3
// SoftwareSerial softBrain(4, 3);
Brain brain(Serial);
void error(char *str)
// Serial.print("error: ");
Serial.println(str);
// red LED indicates error
digitalWrite(redLEDpin, HIGH);
while(1);
void setup(void)
Serial.println();
Serial.print("freeMemory()=");
Serial.println(freeMemory());
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
error("Card failed, or not present");
// Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
// Serial.print("Logging to: ");
Serial.println(filename);
// connect to RTC
Wire.begin();
if (!RTC.begin()) {
#if ECHO_TO_SERIAL
logfile.println("millis,stamp,datetime,light,temp,vcc");
#if ECHO_TO_SERIAL
Serial.println("millis,stamp,datetime,light,temp,vcc");
// If you want to set the aref to something other than 5v
analogReference(EXTERNAL);
void loop(void)
// Expect packets about once per second.
// The .readCSV() function returns a string (well, char*) listing the most recent brain data, in the following format:
// "signal strength, attention, meditation, delta, theta, low alpha, high alpha, low beta, high beta, low gamma, high gamma"
// delay for the amount of time we want between readings
// delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
if (brain.update()){
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print(", ");
#endif
#if RTC_INCLUDE
DateTime now;
// fetch the time
now = RTC.now();
// log time
// logfile.print(now.unixtime()); // seconds since 1/1/1970
logfile.print('"');
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
logfile.print('"');
#if ECHO_TO_SERIAL
// Serial.print(now.unixtime()); // seconds since 1/1/1970
Serial.print(", ");
Serial.print('"');
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
Serial.print('"');
#endif
/* analogRead(photocellPin);
delay(10); */
int photocellReading = 1023;
/* analogRead(tempPin);
delay(10);
int tempReading = analogRead(tempPin);
// converting that reading to voltage, for 3.3v arduino use 3.3, for 5.0, use 5.0
float voltage = tempReading * aref_voltage / 1024;
float temperatureC = (voltage - 0.5) * 100 ;
float temperatureF = (temperatureC * 9 / 5) + 32;
logfile.print(photocellReading);
// logfile.print(", ");
// logfile.print(temperatureF);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(photocellReading);
// Serial.print(", ");
// Serial.print(temperatureF);
char* brainerrors = brain.readErrors();
char* brainCSV= brain.readCSV();
Serial.println(brainerrors);
Serial.println(brainCSV);
logfile.println(brainerrors);
logfile.println(brainCSV);
// Log the estimated 'VCC' voltage by measuring the internal 1.1v ref
/* analogRead(BANDGAPREF);
delay(10);
int refReading = analogRead(BANDGAPREF);
float supplyvoltage = (bandgap_voltage * 1024) / refReading;
logfile.print(supplyvoltage);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(supplyvoltage);
#endif // ECHO_TO_SERIAL
logfile.println();
#if ECHO_TO_SERIAL
Serial.println();
digitalWrite(greenLEDpin, LOW);
// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
// blink LED to show we are syncing data to the card & updating FAT!
logfile.flush();
digitalWrite(redLEDpin, LOW);
freeMemory()=308
Initializing SD card...LOGGER12.CSV
millis,datetime,eegSignalQuality,eegAttention,eegMeditation,eegDelta,eegTheta,eegLowAlpha,eegHighAlpha,eegLowBeta,eegHighBeta,eegLowGamma,eegMidGamma,eegErrors,arduinoVcc
33204,,200,0,0,961704,948936,321243,799999,353993,680961,159887,680403,,1.10
34200,,200,0,0,1178073,1126832,19134,293223,318321,313967,117719,944390,,1.10
35197,,200,0,0,915391,606309,227217,520855,255481,220556,167184,1536422,,1.10
$ cat /Volumes/UNTITLED/LOGGER12.CSV
,1.10
,1.10
,1.10
36194,,200,0,0,546763,793062,122126,196001,74772,523084,220101,898616
,1.10
37191,,200,0,0,512321,926258,50426,411561,193521,307559,140287,846748
,1.10
38188,,200,0,0,741632,685952,111663,314725,144079,442628,177630,644404
,1.10
39184,,200,0,0,928219,1100698,104559,166973,106187,226251,103925,1673322
,1.10
40181,,200,0,0,1152892,704336,131955,484996,201688,557181,92337,1089919
,1.10
// Logs data from a connected EEG toy using the Brain library to an SD card plugged into an Adafruit Data Logger Shield
#include <SD.h>
#include <Brain.h>
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second -- deprecated
// #define LOG_INTERVAL 1000 // mills between entries (reduce to take more/faster data)
#define redLEDpin 2
// the logging file
File logfile;
// Create a new Brain object on hardware serial
// (listening on the RX pin)
while(1);
void setup(void)
Serial.println();
// for troubleshooting, tell us how much RAM is left
if (! logfile) {
/* comment this block out if removing Wire.h/RTC.h from includes
// connect to RTC
// Wire.begin();
if (!RTC.begin()) {
#if ECHO_TO_SERIAL
logfile.println("millis,datetime,eegSignalQuality,eegAttention,eegMeditation,eegDelta,eegTheta,eegLowAlpha,eegHighAlpha,eegLowBeta,eegHighBeta,eegLowGamma,eegMidGamma,eegErrors,arduinoVcc");
#if ECHO_TO_SERIAL
Serial.println("millis,datetime,eegSignalQuality,eegAttention,eegMeditation,eegDelta,eegTheta,eegLowAlpha,eegHighAlpha,eegLowBeta,eegHighBeta,eegLowGamma,eegMidGamma,eegErrors,arduinoVcc");
void loop(void)
logfile.print(",");
#if ECHO_TO_SERIAL
Serial.print(",");
#endif
/* comment all this out if removing Wire.h/RTC.h
DateTime now;
// fetch the time
now = RTC.now();
// log time
logfile.print('"');
logfile.print("/");
logfile.print("/");
logfile.print(" ");
logfile.print(":");
logfile.print(":");
logfile.print('"');
#if ECHO_TO_SERIAL
Serial.print('"');
Serial.print("/");
Serial.print("/");
Serial.print(" ");
Serial.print(":");
Serial.print(":");
Serial.print('"');
// on to the good stuff, print/log the EEG data
#if ECHO_TO_SERIAL
Serial.print(",");
Serial.print(brainCSV);
Serial.print(",");
Serial.print(brainerrors);
logfile.print(",");
logfile.print(",");
delay(10);
logfile.print(",");
#if ECHO_TO_SERIAL
Serial.print(",");
logfile.println();
#if ECHO_TO_SERIAL
Serial.println();
logfile.flush();
freeMemory()=308
Initializing SD card...LOGGER13.CSV
19715,,200,0,0,278012,668842,142325,320505,490834,118212,85457,572401,ERROR: Checksum,1.10
20711,,200,0,0,287682,1894180,66595,371821,45959,382731,145089,1453104,ERROR: Checksum,1.10
21708,,200,0,0,322068,213904,37648,73432,12146,73968,29015,348077,ERROR: Checksum,1.10
22705,,200,0,0,631892,1031669,32419,164952,64483,458654,112229,675881,ERROR: Checksum,1.10
23702,,200,0,0,619217,1467119,129039,405954,75416,666706,114956,810149,ERROR: Checksum,1.10
28389,,80,0,0,473687,860884,116241,352291,290308,851508,158445,662009,ERROR: Checksum,1.10
29385,,80,0,0,575739,882394,99855,833027,244817,448659,192398,686223,ERROR: Checksum,1.10
30383,,80,0,0,1083259,886526,31010,527803,184641,267780,154211,1294269,ERROR: Checksum,1.10
37548,,80,0,0,426591,1293735,228691,259559,143018,banned,77287,1061194,ERROR: Checksum,1.10
38544,,80,0,0,696424,795286,119708,749761,171988,512470,181959,754365,ERROR: Checksum,1.10
$ cat /Volumes/UNTITLED/LOGGER13.CSV
#include <SD.h>
#include <Brain.h>
#define redLEDpin 2
// the logging file
File logfile;
while(1);
void setup(void)
Serial.println();
if (! logfile) {
// connect to RTC
// Wire.begin();
if (!RTC.begin()) {
#if ECHO_TO_SERIAL
#if ECHO_TO_SERIAL
void loop(void)
logfile.print(",");
#if ECHO_TO_SERIAL
Serial.print(",");
#endif
DateTime now;
// fetch the time
now = RTC.now();
// log time
logfile.print('"');
logfile.print("/");
logfile.print("/");
logfile.print(" ");
logfile.print(":");
logfile.print(":");
logfile.print('"');
#if ECHO_TO_SERIAL
Serial.print('"');
Serial.print("/");
Serial.print("/");
Serial.print(" ");
Serial.print(":");
Serial.print(":");
Serial.print('"');
#if ECHO_TO_SERIAL
Serial.print(",");
Serial.print(",");
logfile.print(",");
logfile.print(brainCSV);
logfile.print(",");
logfile.print(brainerrors);
delay(10);
logfile.print(",");
#if ECHO_TO_SERIAL
Serial.print(",");
logfile.println();
#if ECHO_TO_SERIAL
Serial.println();
logfile.flush();
set datafile separator ","
set key autotitle columnhead
set autoscale x
set yrange [0:1500000]
set y2range [0:100]
set parametric
plot for [i=6:13] file using 1:i with lines smooth bezier, file using 1:3 with lines axis x1y2 smooth csplines #, for [i=4:5] file using 1:i with lines lw 2 axis x1y2 smooth bezier
gnuplot -e "file='/Path/to/LOGGER00.CSV'" /Path/to/eeg.gpl
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 5 guests
