Controling the 36mm Square RGB LED Pixels - WS2801
Postby bluegroup » Sun Jun 03, 2012 8:53 am
Hi All,
I'm creating a 6x6 matrix (total36) using the 36mm Square 12V Digital RGB LED Pixels.
I have successfully run the strandtest.pde and it works like a dream.
However I'm stuck on how to control individual squares. For example, lets say I would like an orange "X" and the rest to be blue in the 6x6 matrix.
How would i achieve this or is there a mac controller to do this with? I really would appreciate any help as I'm more of a hardware guy!
bluegroup
Re: Controling the 36mm Square RGB LED Pixels - WS2801
Postby adafruit_support_bill » Sun Jun 03, 2012 9:15 am
Start by numbering all the pixels in your diagram - starting with #0 at the arrow. You can control the color of each pixel with calls to "strip.setPixelColor(i, c)", where 'i' is the pixel number and 'c' is the color. Colors can be set using the "Color(r, g, b)" function where r = red, g = green & b = blue. (You will probably have to experiment a bit to find the right mix of R, G & B to get the colors you want.
For example - to set pixel 0 to orange (I'm guessing at the color mix a little)
strip.SetPixelColor(0, Color(255, 128, 0));
And to set pixel #1 to blue:
strip.SetPixelColor(0, Color(0, 0, 255));
Once you have all the pixels colors set, call "strip.show()" to display them on the strip.
Postby mtbf0 » Sun Jun 03, 2012 3:28 pm
if you'd like to address your pixels as positions on a cartesian sort of grid, it might be worthwhile to rotate the whole thing so the first pixel is at the upper left with the second pixel to its right and the twelfth pixel below the first, then you could do a calculation along the lines of this...
  strip.SetPixelColor ((y * 6) + ((y & 1) ? (5 - x) : x), Color(r, g, b));
where y is an int indicating the pixel's row and x is an int indicating it's column. keep in mind that the first row is row 0 and the last row is row 5. same goes for the columns. r, g, and b are ints that indicate the red, green and blue components of the color you want.
mtbf0
Postby bluegroup » Tue Jun 05, 2012 8:33 am
Thanks for the help guys, I managed to get an "x" using the following bit of code
void MAKEx()
int r = 100;
int g = 100;
int b = 100;
strip.setPixelColor(0,Color(g, r, b));//grd
strip.setPixelColor(5,Color(g, r, b));//grd
strip.setPixelColor(7,Color(g, r, b));//grd
strip.setPixelColor(10,Color(g, r, b));//grd
strip.setPixelColor(14,Color(g, r, b));//grd
strip.setPixelColor(15,Color(g, r, b));//grd
strip.setPixelColor(20,Color(g, r, b));//grd
strip.setPixelColor(21,Color(g, r, b));//grd
strip.setPixelColor(25,Color(g, r, b));//grd
strip.setPixelColor(28,Color(g, r, b));//grd
strip.setPixelColor(30,Color(g, r, b));//grd
strip.setPixelColor(35,Color(g, r, b));//grd
strip.show();
Is there a way to make the code better?
I was also wondering how I could fade in and out the "x".
Any advice would be appreciated.
bluegroup
Postby adafruit_support_rick » Tue Jun 05, 2012 8:56 am
There are a million ways to make the code better. It all depends on what you ultimately want to do with this. Can you give us some idea?
Postby bluegroup » Tue Jun 05, 2012 9:45 am
I should have said
Is it possible to reduce the amount of code so it doesn't be come too labor intensive.
bluegroup
Postby adafruit_support_rick » Tue Jun 05, 2012 2:43 pm
"Better" and "less labor-intensive" are the same thing. The short answer is that you want to think about patterns.
If you are only going to have a few fixed patterns (for example, if your 'X' is part of a font you're planning to construct), then you want to think about using lookup tables for colors and intensities. You can write a simple loop to pull the pattern's colors and intensities out of one or more tables and write it to the lights. You could have a simple algorithm to do fades and color changes based on the fixed font patterns.
If you want to do some sort of random-looking psychedelic light show, then you want to think about algorithms to generate patterns, mix colors, cycle through different patterns etc.
My rule of thumb for stuff like this is that I want my code to be as simple and stupid as possible. I want to put the smarts into my data structures. Sometimes that takes a little more thought and work up front, but it pays off later on.
Postby bluegroup » Tue Jun 12, 2012 2:19 am
I would suggest the two below, unfortunately they don't work with the WS2801.
I'm all but giving up on the WS2801 as there's not a lot of support or controllers for them.
Try:
http://pixelinvaders.ch/
http://www.idolstarastronomer.com/char-pixel_paint
bluegroup
Postby mtbf0 » Tue Jun 12, 2012 4:12 pm
bluegroup, try this. it compiles, but i don't have a ws2801 strip to test it on. should fade your orange x on a blue background in, hold for a second, then fade the orange to blue. pretty rudimentary.
#include "SPI.h"
#include "Adafruit_WS2801.h"
#define DATA_LENGTH 36
uint8_t datums[] = {1,0,0,0,0,1,0,1,0,0,1,0,0,0,1,1,0,0,0,1,0,0,1,0,1,0,0,0,0,1};
uint32_t fg, bg;
uint8_t fg_color[] = {0,0,0};
uint8_t bg_color[] = {0,0,0};
Adafruit_WS2801 strip = Adafruit_WS2801(36);
uint32_t Color(uint8_t r, uint8_t g, uint8_t b) {
  uint32_t c;
  c = r;
  c <<= 8;
  c |= g;
  c <<= 8;
  c |= b;
  return c;
void display () {
  bg = Color (bg_color[0], bg_color[1], bg_color[2]);
  fg = Color (fg_color[0], fg_color[1], fg_color[2]);
  for (int i = 0; i < DATA_LENGTH; i++) {
    if (datums[i]) strip.setPixelColor(i, fg);
    else strip.setPixelColor(i, bg);
  strip.show ();
void fade (int steps, int d) {
  float start[] = {0.0, 0.0, 0.0};
  float end[] = {0.0, 0.0, 0.0};
  float interval[] = {0.0, 0.0, 0.0};
  int i, j;
  for (i = 0; i < 3; i++) {
    start [i] = (float) fg_color[i];
    interval[i] = ((float) bg_color[i] - start[i]) / (float) steps;
  for (j = 1; j < steps; j++) {
    fg = Color ((uint8_t)start[0], (uint8_t)start[1], (uint8_t)start[2]);
    strip.show ();
    start[0] += interval[0];
    start[1] += interval[1];
    start[2] += interval[2];
    delay (d);
    if (datums[i]) strip.setPixelColor(i, bg);
  strip.show ();
  strip.begin();
  strip.show();
  for (i = 0; i < 128; i++) {
    bg_color[2] += 2;
    fg_color[0] += 2;
    fg_color[1] += 1;
    display ();
    delay (8);
void loop () {
  display ();
  delay (1000);
  fade (256, 4);
  delay (1000);
mtbf0
Postby bluegroup » Tue Jun 12, 2012 7:31 pm
Thanks mtbf0
I really appreciate the time and effort you have put.
I'll definitely let you know how I go, this sure has given me hope!
bluegroup
Postby mtbf0 » Tue Jun 12, 2012 8:26 pm
failed to notice that your strip is grb, so you'll want to change lines like
to
  bg = Color (bg_color[1], bg_color[0], bg_color[2]);
  fg = Color (fg_color[1], fg_color[0], fg_color[2]);
fortunately it comes to changing about 8 characters and they're all ones and zeros. without the changes your orange will be kind of gold.
mtbf0
Postby bluegroup » Wed Jun 13, 2012 8:23 am
Thanks mtbf0,
I had to make a few mods to the code but I did get it working!
#include "SPI.h"
int dataPin  = 2;
int clockPin = 3;
Adafruit_WS2801 strip = Adafruit_WS2801(36, dataPin, clockPin);
uint8_t datums[] = {1,0,0,0,0,1,0,1,0,0,1,0,0,0,1,1,0,0,0,0,1,1,0,0,0,1,0,0,1,0,1,0,0,0,0,1};
uint32_t fg, bg;
  uint32_t c;
  c = r;
  c <<= 8;
  c |= g;
  c <<= 8;
  c |= b;
  return c;
void display () {
  strip.show ();
  int i, j;
    strip.show ();
    delay (d);
  strip.show ();
  strip.begin();
  strip.show();
  for (int i = 0; i < 255; i++) {
   bg_color[2] += 2;
    fg_color[0] += 2;
    fg_color[1] += 1;
    display ();
    delay (8);
void loop () {
  display ();
  delay (1000);
  fade (256, 4);
  delay (1000);
bluegroup
Postby mtbf0 » Wed Jun 13, 2012 11:33 pm
bluegroup wrote:I had to make a few mods to the code but I did get it working!
excellent.
mtbf0
Postby toreseng » Mon Jun 03, 2013 6:16 pm
Along the same topic here of controlling these 36mm Square RGB LED Pixels - but slightly different.
Is it possible to set up a 2D array that maps the locations of these Pixels as a square shape? Instead of reading them in as a strand?
EX: I know it is possible to control a 2D array and iterate through each row and make it as if the rows were animating in a downward scrolling manner. With that how can you keep the original shape of the 6 x 6 and control the LEDs with the controllablity of using arrays to animate them?
I guess what I'm asking, if it's not very clear, is how do I create a 2D Array such as ( LED_Array [5][5] ) and map the individual Pixel to each coordinate?
I'm in the process of linking 200 of these together and am having trouble with an easy way of organizing the way I control them.
toreseng
Postby adafruit_support_rick » Mon Jun 03, 2013 10:09 pm
You could fill the array with code at run-time, something like this:
#define NUM_ROWS 5
#define NUM_COLS 5
int LED_Array[NUM_ROWS][NUM_COLS]; //contains pixel indices
    for (int row = 0; row < NUM_ROWS; row++)
        for (int col = 0; col < NUM_COLS; col++)
            LED_Array[row][col] = (row * NUM_ROWS) + col;
Or, you could use a static initializer, something like this:
#define NUM_ROWS 5
#define NUM_COLS 5
int LED_Array[NUM_ROWS][NUM_COLS] = {     //contains pixel indices
                                         { 0,  1,  2,  3,  4},
                                         { 5,  6,  7,  8,  9},
                                         {10, 11, 12, 13, 14},
                                         {15, 16, 17, 18, 19},
                                         {20, 21, 22, 23, 24}
Next
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: No registered users and 3 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
