Once I get past that, I would like to investigate sending those signals down a wire ( think perimeter wire ).
Any thoughts or suggestions would be greatly appreciated!!
The LM386 may be a little weak in the volume-capability department. 120-dB loudness is on the order of a jet engine backwash.mstone@yawp.com wrote:Any of the (many) portable amps based on the LM386 should do the job
bunger wrote:I would need to generate sound in the ultrasonic range ( greater than 20kHz ) and louder than 120dB.
My mistake. When you indicated 120-dB, I thought you were referring to audio volume levels instead of electrical watts.
I think we are on the same page here.mstone@yawp.com wrote:you're right that I assumed a speaker would convert eletrical power to sound pressure with 100% efficiency
Users browsing this forum: No registered users and 8 guests
