Does the NFC/RFID Controller Shield have anti-collision support?
Postby rocketblast » Mon Jun 11, 2012 6:04 am
Adafruit PN532 NFC/RFID Controller Shield for Arduino
http://www.adafruit.com/products/789
Does this shield have anti-collision support?
If not, is this a hardware or software limitation?
rocketblast
Re: Does the NFC/RFID Controller Shield have anti-collision support?
Postby adafruit » Tue Jun 12, 2012 9:44 am
The PN532 can read up to 2 cards at a time - check the PN532 documentation for any more details about anti-collision support - we've dont remember seeing anything about it & anything the PN532 supports, the shield supports (altho there may not be example code for it)
please post up what you find!
Postby rocketblast » Wed Jun 13, 2012 12:44 am
From skimming the manual it looks like some of the commands will return a specific error code when there is a collision. One then has the option to send a select command to pick the desired target and then re-run the command.
Section 7.3.5 shows the InListPassiveTarget command, which lists the available targets. You are correct that the 532 can only detect up to two targets.
rocketblast
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 5 guests
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
