It works quite well. I tried at home on Sony, Sharp, LG TVs without any problem. I use it not only turning OFF the TVs but also turning ON the TVs.
However, the problem is the power source. Even though I added a 50ohm resistor to the IR LED, with the supercaps (of course it has much little juice than real batteries), I could use it only a dozen times. There are also other things that limits its lifetime such as using internal resonator (varies upon temperature and power voltages) and I used ATtiny85, not 85V, but it must be mostly because of small capacity of the supercaps (although it is 'super'
So, my question is, how long can you continuously use the Adafruit's 4 LED TV-B-Gone with AA alkaline batteries or NiCd, NiMH?
Thanks.
Jinseok
