DS1307 Clock not Working
For RTC breakouts, etc., use the Other Products from Adafruit forum
techguy777
Post by techguy777 »
Hi.
I am having a problem with my ds1307. It was working fine and then all of a sudden it stopped working correctly. I am running the example code for the rtc library
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
void setup () {
    Serial.begin(57600);
    Wire.begin();
    RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
    DateTime now = RTC.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.println();
    Serial.print(" since midnight 1/1/1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days and 30 seconds into the future
    DateTime future (now.unixtime() + 7 * 86400L + 30);
    Serial.print(" now + 7d + 30s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    Serial.println();
    Serial.println();
    delay(3000);
When I'm running the problem I get the following response from the Serial Connection.
2165/165/165 165:165:85
since midnight 1/1/1970 = 1402703185s = 16234d
now + 7d + 30s: 2014/6/20 23:46:55
I have checked all the wiring and soldering connections and they all look good.
Thanks in advance!
adafruit_support_rick
Re: DS1307 Clock not Working
Hard to say, but the symptoms sound very much like an intermittent connection. If you post some detailed pictures of the soldering/wiring, we'll have a look at it.
techguy777
Thanks. Here is a picture of the soldering and wiring. Sorry about the poor quality. It's hard to see in the picture but I connected SDA to Digital Pin 4 and SCL to Digital Pin 5. Thanks!
Those photos are much too small to see any detail. Try sizing them to about 800x600
techguy777
Here are the enlarged photos. I apologize about the poor quality.
More light usually helps. Try near a window - or even outside.
techguy777
Updated Pics. Thanks!
Still pretty out of focus, but from what I can see the solder doesn't look bad.
If you run the sketch several times, does the time increment appropriately between sketches?
gragib
Post by gragib »
I have the same problem when I try running the DS1307 with 3.3V instead of 5V.
I would also check 2 other things:
1. Is the coin cell inserted the right way - positive side up?
2. Is the coin cell providing sufficient voltage?
From reading the spec sheet for the DS1307, it seems that a proper coin cell is absolutely necessary for correct operation of the chip.
csabee
Post by csabee »
I have a strange problem with a DS1307 chip.
I'm using it with an arduino mega adk r3, wired the sda/scl to digital 20 and 21 pins.
I have started from the adafruit sample code. Managed to adjust the time for 2013/2/23 21:48:58
void loop () {
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    Serial.println();
    Serial.print(" since 1970 = ");
    delay(3000);
And now I have a problem with the output:
2013/2/23 21:48:58
 since 1970 = 1361656138s = 15759d
2013/2/23 21:48:58
2013/2/23 21:48:58
2013/2/23 21:48:58
2013/2/23 21:48:58
2013/2/23 21:48:58
So the problem is that the DS1307 won't tick, it just stores the adjusted time.
Can you help me, what could be the problem?
Thank you!
Is this an Adafruit DS1307 breakout board or a bare chip?
csabee
Post by csabee »
No, this one is from ebay, but it has a similar breakout.
I'm sorry, but you'll have to contact the seller or manufacturer for technical support.
ockeydockey
Post by ockeydockey »
I too am having this problem. I have the breakout board from Adafruit for the DS1307. After setting the time with a Raspberry Pi I use it with a Trinket 5v. It keeps perfect time for a good long while, and then stops incrementing. My code recalculate's the display every time it gets a reading, and it keeps repeating the same time. When I hook it back up to the Raspberry Pi (before setting the time again), it starts incrementing again from the time that it was stuck on.
Have you tried a fresh backup battery?
Please post clear, detailed pictures of both sides of the board, showing your soldering.
Return to “Clock Kits (discontinued)”
