POWERED USB HUB QUESTION
by SparkzCrossedWires on Fri Oct 26, 2012 3:12 pm
I recently purchased a powered 7-port USB hub and it has really made a difference in the performance of my WIFI dongle and stabilized the system. I am interested in using a Power Pack to run my Raspberry Pi so I don't have to have the wall wart tethered to an outlet.
The Power Pack has 2 USB ports, but the cable I was using on my previous hub has a different size barrel plug and will not fit your hub. Do you have a relatively short USB to barrel jack cable available for this?
SparkzCrossedWires
Re: POWERED USB HUB QUESTION
by adafruit on Sat Oct 27, 2012 9:38 am
We do not :(
by SparkzCrossedWires on Sat Oct 27, 2012 10:02 am
Would you please confirm the size of the barrel jack supplied so I can try to source it somewhere else?
SparkzCrossedWires
by adafruit on Mon Oct 29, 2012 9:16 am
We don't know or have any specifications for it, sorry!
by ericbnyc on Fri Nov 02, 2012 9:35 am
I have an additional question about the 7 port usb powered hub (two questions, really)
1 - What's the power output on each port? I've read that a Raspberry Pi would do best with 700ma and if I wanted to use this to power the Pi I'd like to know the power specs. Most hubs seem to be 500ma / port
2- When will it be back in stock? The web page has the stock "5 to 10 days" comment.
thanks, & good luck spinning back up after the storm!
-e
ericbnyc
