0 reading from MCP3008
by egutting on Wed Nov 14, 2012 1:02 am
I am working on the learning project where you capture the temperature and load it to COSM. I have the RPi set up and the code seems to be working correctly. The problem is it keeps reading the adc0 as 0 which shows as -50 C & -58 F. I have checked the TMP36 and it is reading .75 volts and I have bypassed the cobbler and wired straight into the ribbon (to check my soldering). Could my MCP3008 be bad, or am I missing something? I wired the breadboard identical to the images shown.
Joe Gutting
egutting
Re: 0 reading from MCP3008
by adafruit on Thu Nov 15, 2012 11:57 pm
its unlikely that the chip is bad, how about you start over with the cobbler, then post a clear photo of your wiring? we'll check it out! Also, post a screenshot of the output of the python sketch
by egutting on Fri Nov 16, 2012 2:23 am
Looks like I needed to do an update on apt-get as once I did that everything seemed to install correctly and it is working now.
egutting
by adafruit on Fri Nov 16, 2012 9:24 am
great :)
