RTC Issue
RTC Issue
by bmco2n on Sun Nov 18, 2012 6:01 pm
Dear Forum,
Using the Ladyada download for RTC from the datalogger tutorial,
The following sketch compiles and loads OK, but fails the “RTC is NOT running” test. Examples > RTC > ds1307 does the same. Removing the test, as suggested by Adafruit forum and just using RTC.adjust(DateTime(__DATE__, __TIME__)); doesn’t work. Deleting RTClib in the Arduino library and downloading Ladyada’s RTClib.master again, unzipping and renaming it to RTClib in the libraries doesn’t work. Any suggestions?
//TMP36 Pin Variables
#include <Wire.h>
#include "RTClib.h"
#include <SoftwareSerial.h>
SoftwareSerial mySerial = SoftwareSerial(0,1);
RTC_DS1307 RTC;
int sensorPin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
//the resolution is 10 mV / degree centigrade with a
//500 mV offset to allow for negative temperatures
 * setup() - this function runs once when you turn your Arduino on
 * We initialize the serial connection with the computer
void setup()
  Serial.begin(9600);  //Start the serial connection with the computer
  Wire.begin();
  RTC.begin();
  if(! RTC.isrunning()) {
    Serial.println("RTC NOT running");
  Serial.println("goodbye moon");
  Serial.println("hour, minutes, seconds, volts, degC,  degF");
  mySerial.begin(9600);
  mySerial.print("Hello World");
  mySerial.print("hour, minutes, seconds, volts, degC,  degF");
void loop()                     // run over and over again
  DateTime now = RTC.now();
  Serial.print(now.day());
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(" ");
  Serial.print(now.minute(), DEC);
  Serial.print(" ");
  Serial.print(now.second(), DEC);
  Serial.print(", ");
  //getting the voltage reading from the temperature sensor
  int reading = analogRead(sensorPin);
  // converting that reading to voltage, for 3.3v arduino use 3.3
  float voltage = reading * 5.0;
  voltage /= 1024.0;
  // print out the voltage
  Serial.print(voltage);
  Serial.print("  ");
  // now print out the temperature
  float temperatureC = (voltage - 0.47) * 100 ;  //converting from 10 mv per degree wit 500 mV
  //to degrees ((volatge - 500mV) times 100)
  Serial.print(temperatureC);
  Serial.print("   ");
  // now convert to Fahrenheight
  float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
  Serial.println(temperatureF);
  mySerial.print(now.hour(), DEC);
  mySerial.print(" ");
  mySerial.print(now.minute(), DEC);
  mySerial.print(",  ");
  mySerial.print(voltage);
  mySerial.print(temperatureC);
  mySerial.println(temperatureF);
  delay(15000);                                     //waiting a second
Thanks for looking :D
bmco2n
Re: RTC Issue
by adafruit_support_bill on Mon Nov 19, 2012 7:49 am
If you post clear photos of the front and back of your shield, we will check your assembly.
Re: RTC Issue
by bmco2n on Mon Nov 19, 2012 2:34 pm
:oops: Sorry, I misled you by mentioning the datalogger. I'm using the Xbee shield from Sparkfun.
bmco2n
Re: RTC Issue
by adafruit_support_bill on Tue Nov 20, 2012 6:40 am
So, are you using the DS1307 breakout? If you post photos of that we will check your soldering.
Re: RTC Issue
by bmco2n on Fri Nov 23, 2012 12:17 pm
Dear Adafruit Support,
Your last answer was a wise aphorism, hinting that I should describe my system in detail, which I didn't. I"m using a Sparkfun Xbee shield atop an Arduino UNO, communicating to another Xbee on a Sparkfun Explorer board hooked to my laptop. Fortunately, I didn't do any soldering on these and I suspect you remember how bad I am at soldering and photography. The program I listed in my original question is using the ds1407 software, like the example for RTClib. Neither program will open RTC. My sketch works fine when I use millis() instead of RTC. Am I slowly beginning to see to my horror that I need the RTC chip with the little coin battery attached to use RTC? It isn't. Humiliated, I still thank you as a loyal (but stupid) student. :oops:
bmco2n
