HAPPY LABOR DAY - ADAFRUIT IS OPEN - ALL ORDERS PLACED AFTER 11AM ET 9/4/2015 WILL NOT SHIP UNTIL TUESDAY 9/8/2015 - READ MORE!
Arduino ATAPI CD/ROM
by cry4brk on Wed Nov 14, 2012 6:16 pm
Hi, I fund this project: http://singlevalve.web.fc2.com/Atapiduino/atapiduino.htm
My questions are:
If I verify the sketch in arduino software it give a lot of errors. Can anyone check the latest one and tell me how to fix it?
And the secound one is, On the website it is writen that you have to connect it to A4 and A5 on arduino board (SDA, SCL). My Arduino R3 SMD edition have two extra pins called SDA an SCL do I have to modify the code again or just connect it to A4, A5
Many thanks in advance, and i really want to make this project. Thanks
    Simple IDE ATAPI controller using the Arduino I2C interface and
    3 PCF8574 I/O expanders. Release 3.1 using a 4th PCF8574 I/O
    expander interfacing to a 1602 LCD.
    Copyright (C) 2012  Carlos Durandal
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNES.S FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
    PCF8574   A2,A1,A0     Addr.
        #1     0  0  0     0x20    interfaces to IDE DD0-DD7
        #2     0  0  1     0x21    interfaces to IDE DD8-DD15
        #3     0  1  0     0x22    interfaces to the IDE register selection see details below.
        #4     1  1  1     0x27    interfaces to the LCD
    PCF8574#3 bit:    7     6    5    4    3   2   1   0
    IDE pin:        nDIOR nDIOW nRST nCS1 nCS0 DA2 DA1 DA0
     pin names with leading 'n' are active LOW
#include <Wire.h>                  // I2C bus library
// This sketch uses F Malpartida's NewLiquidCrystal library. Obtain from:
// https://bitbucket.org/fmalpartida/new-liquidcrystal
#include <LiquidCrystal_I2C.h>     // I2C LCD library
// Start of Definitions
// I/O expander addresses:
const int DataL = 0x20;            // IDE DD0-DD7
const int DataH = 0x21;            // IDE DD8-DD15
const int RegSel = 0x22;           // IDE register
const int LCD_I2C_ADDR = 0x27;     // LCD (SainSmart 1602)
/* Note that the 'pins' in the following LCD definitions are not IC pins numbers
but rather specify the PCF8574 I/O port numbers: P0 to P7. E.g. LCD 'En' pin is
connected to port P2 of PCF8574 so En_pin = 2. */
const byte BACKLIGHT_PIN = 3;
const byte En_pin = 2;
const byte Rw_pin = 1;
const byte Rs_pin = 0;
const byte D4_pin = 4;
const byte D5_pin = 5;
const byte D6_pin = 6;
const byte D7_pin = 7;
LiquidCrystal_I2C lcd(LCD_I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
// IDE Register addresses
const byte DataReg = 0xF0;         // Addr. Data register of IDE device.
const byte ErrFReg = 0xF1;         // Addr. Error/Feature (rd/wr) register of IDE device.
const byte SecCReg = 0xF2;         // Addr. Sector Count register of IDE device.
const byte SecNReg = 0xF3;         // Addr. Sector Number register of IDE device.
const byte CylLReg = 0xF4;         // Addr. Cylinder Low register of IDE device.
const byte CylHReg = 0xF5;         // Addr. Cylinder High register of IDE device.
const byte HeadReg = 0xF6;         // Addr. Device/Head register of IDE device.
const byte ComSReg = 0xF7;         // Addr. Command/Status (wr/rd) register of IDE device.
const byte AStCReg = 0xEE;         // Addr. Alternate Status/Device Control (rd/wr) register of IDE device.
// Program Variables
byte dataLval;                     // dataLval and dataHval hold data from/to
byte dataHval;                     // D0-D15 of IDE
byte regval;                       // regval holds addr. of reg. to be addressed on IDE
byte reg;                          // Holds the addr. of the IDE register with adapted
                                   // nDIOR/nDIOW/nRST values to suit purpose.
byte cnt;                          // packet byte counter
byte idx;                          // index used as pointer within packet array
byte paclen = 12;                  // Default packet length
byte s_trck;                       // Holds start track
byte e_trck;                       // Holds end track
byte c_trck;                       // Follows current track while reading TOC
byte c_trck_m;                     // MSF values for current track
byte c_trck_s;
byte c_trck_f;
byte a_trck = 1;                   // Holds actual track from reading subchannel data
byte MFS_M;                        // Holds actual M value from reading subchannel data
byte MFS_S;                        // Holds actual S value from reading subchannel data
byte d_trck;                       // Destination track
byte d_trck_m;                     // MSF values for destination track
byte d_trck_s;
byte d_trck_f;
byte aud_stat = 0xFF;              // subchannel data: 0x11=play, 0x12=pause, 0x15=stop
byte asc;
long prev_millis=0;
long interval=100;
boolean toc;
// Array containing sets of 16 byte packets corresponding to part of the CD-ROM
// ATAPI function set. If the IDE device only supports packets with 12 byte length
// the last 4 bytes are not sent. The great majority of tested devices use 12 byte.
byte fnc[]= {
  0x1B,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=0 Open tray
  0x1B,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=16 Close tray
  0x1B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=32 Stop unit
  0x47,0x00,0x00,0x10,0x28,0x05,0x4C,0x1A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=48 Start PLAY
  0x4B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=64 PAUSE play
  0x4B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=80 RESUME play
  0x43,0x02,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=96 Read TOC
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=112 unit ready
  0x5A,0x00,0x01,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=128 mode sense
  0x42,0x02,0x40,0x01,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=144 rd subch.
  0x03,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // idx=160 req. sense
  0x4E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00  // idx=176 Stop disk
// Arduino pin assignments:
const byte LED = 13;
const byte NEXT = 12;                   // NEXT button
const byte EJCT = 11;                   // EJECT button, open/close CD-ROM tray
const byte STOP = 10;                   // STOP button
const byte PLAY = 9;                    // PLAY button
const byte PREV = 8;                    // PREV button
// End of Definitions ########################################################################
void setup(){
  // LCD Part
  lcd.begin (16,2);                                // init LCD interface
  // Switch on the backlight
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home ();                                     // set cursor to home position
  // Arduino Part
  // start I2C interface as Master
  Wire.begin();
  // Set all pins of all PCF8574 to high impedance inputs.
  highZ();
  // Start Serial Interface
//  Serial.begin(9600);
  // initialize the push button pins as inputs with pullup:
  pinMode(NEXT, INPUT);
  pinMode(PREV, INPUT);
  pinMode(EJCT, INPUT);
  pinMode(STOP, INPUT);
  pinMode(PLAY, INPUT);
  pinMode(LED, OUTPUT);
  digitalWrite(NEXT, HIGH);
  digitalWrite(PREV, HIGH);
  digitalWrite(EJCT, HIGH);
  digitalWrite(STOP, HIGH);
  digitalWrite(PLAY, HIGH);
  digitalWrite(LED, LOW);
// IDE Initialisation Part
  lcd.print("Atapiduino");
  lcd.setCursor (0,1);                      // cursor to beginning of LCD 2nd. line
  lcd.print("Release 3.1");
  reset_IDE();                              // Do hard reset
  delay(3000);                              // This delay waits for the drive to initialise
  BSY_clear_wait();                         // The ATAPI spec. allows drives to take up to
  DRY_set_wait();                           // 31 sec. but all tested where alright within 3s.
  lcd.clear();
  readIDE(CylLReg);                         // Check device signature for ATAPI capability
  if(dataLval == 0x14){
    readIDE(CylHReg);
    if(dataLval == 0xEB){
         lcd.print("Found ATAPI Dev.");
  }else{
         lcd.print("No ATAPI Device!");
         while(1);                          // No need to go ahead.
  writeIDE(HeadReg, 0x00, 0xFF);            // Set Device to Master (Device 0)
// Initialise task file
   init_task_file();
// Run Self Diagnostic
  delay(3000);
  lcd.clear ();
  lcd.print("Self Diag. ");
  writeIDE(ComSReg, 0x90, 0xFF);            // Issue Run Self Diagnostic Command
  readIDE(ErrFReg);
  if(dataLval == 0x01){
     lcd.print("OK");
  }else{
        lcd.print("Fail");            // Units failing this may still work fine
  delay(3000);
  lcd.clear ();
  lcd.print("ATAPI Device:");
// Identify Device
  writeIDE (ComSReg, 0xA1, 0xFF);           // Issue Identify Device Command
  delay(500);                               // Instead of wait for IRQ. Needed by some dev.
//  readIDE(AStCReg); //
  do{
    readIDE(DataReg);
    if (cnt == 0){                                // Get supported packet lenght
      if(dataLval & (1<<0)){                      // contained in lower byte of first word
        paclen = 16;                              // 1st bit set -> use 16 byte packets
    if(cnt > 26 & cnt < 47){                      // Read Model
        lcd.print(dataHval);
        lcd.print(dataLval);
//        Serial.print(dataHval);
//        Serial.print(dataLval);
    cnt++;
    readIDE(ComSReg);                             // Read Status Register and check DRQ,
  } while(dataLval & (1<<3));                     // skip rest of data until DRQ=0
  readIDE(AStCReg);
  DRQ_clear_wait();
// Check if unit ready
  unit_ready();                                   // Send packet 'test unit ready'
  req_sense();                                    // Send packet 'Request Sense'
  if(asc == 0x29){                                // Req. Sense returns 'HW Reset'
    unit_ready();                                 // (ASC=29h) at first since we had one.
    req_sense();                                  // New Req. Sense returns if media
  }                                               // is present or not.
  do{
     unit_ready();                                // Wait until drive is ready.
     req_sense();                                 // Some devices take some time
  }while(asc == 0x04);                            // ASC=04h -> LOGICAL DRIVE NOT READY
// End of setup
// This part reads the push buttons, checks device audio status, interprets operator commands
// and displays the corresponding data depending on the status and/or the commands resulting
// from pressing the push buttons.
void loop(){
  // Scan push buttons
  if(digitalRead(EJCT) == LOW){
    lcd.clear();
    toc=false;                                    // Set toc invalid
    switch(chck_disk()) {
      case 0x00:                                  // If disk in tray case
      lcd.print("      OPEN");
      eject();
      break;
      case 0xFF:                                  // If tray closed but no disk in case
      eject();
      lcd.print("      OPEN");
      break;
      case 0X71:                                 // If tray open -> close it
      lcd.print("      LOAD");
      load();
    lcd.clear();
    a_trck = s_trck;                             // Reset to start track
  if(digitalRead(STOP) == LOW){
    a_trck=s_trck;                               // Reset to start track
    stop_disk();                                 // Stop Disk
    stop();                                      // Stop unit
    toc=false;
  if(digitalRead(PLAY) == LOW){                  // Play has been pressed
      switch(aud_stat){
         case 0x15:                              // If stopped
         play();                                 // start play
         break;
         case 0x12:                              // if paused
         resume();                               // resume play
         break;
         case 0x11:                              // if playing
         pause();                                // pause playback
    toc=false;                                   // mark TOC unknown in case disk
    lcd.clear();                                 // is removed using device eject buton
  }                                              // while play in progress
  if(digitalRead(NEXT) == LOW){
    a_trck = a_trck + 1;                         // a_track becomes next track
    if(a_trck > e_trck){(a_trck = s_trck);}      // over last track? -> point to start track
    get_TOC();                                   // Get MSF for a_trck
    fnc[51] = d_trck_m;                          // Store new play start position
    fnc[52] = d_trck_s;                          // in play packet and start play
    fnc[53] = d_trck_f;
    play();
    if(aud_stat == 0x12 |                        // If paused or stopped -> pause
       aud_stat == 0x15)
     pause();
    lcd.clear();
  if(digitalRead(PREV) == LOW){                 // Basically like the NEXT function above
    a_trck = a_trck - 1;                        // only backwards
    if(a_trck < s_trck){(a_trck = e_trck);}
    get_TOC();
    fnc[51] = d_trck_m;
    fnc[52] = d_trck_s;
    fnc[53] = d_trck_f;
    play();
       aud_stat == 0x15)
     pause();
    lcd.clear();
  if(millis()-prev_millis > interval){          // This part will periodically check the
    read_subch_cmd();                           // current audio status and update the display
    if(aud_stat==0x11){                         // accordingly.
      lcd.home();
      lcd.print("      PLAY    ");
      curr_MSF();                               // Display pickup position
    if(aud_stat==0x12){
      lcd.home();
      lcd.print("     PAUSE   ");
      curr_MSF();
    if(aud_stat==0x15 & !toc){                  // If stopped and TOC invalid
      get_TOC();                                // try to read TOC
      Disp_CD_data();                           // display TOC data and set TOC valid
      toc=true;                                 // to prevent reading over and over
    if(aud_stat==0x00){                         // Audio status 0 covers all other posible
      lcd.clear();                              // states not decoded by this sketch and
      lcd.print("    NO DISC");                 // handles them as NO DISC.
    prev_millis=millis();
// Auxiliary functions for displaying data
 void Disp_CD_data(){                          // Used to display track range and
     lcd.clear();                              // Total playing time as recovered
     lcd.print("Tracks  ");                    // from reading the TOC
     lcd.print(s_trck, DEC);
     lcd.print("-");
     lcd.print(e_trck, DEC);
     lcd.print("Time   ");
     lcd.print(fnc[54], DEC);
     lcd.print(":");
      if(fnc[55] < 10)
        lcd.print("0");                         // Print a leading 0 for seconds when below 10
      lcd.print(fnc[55], DEC);
void curr_MSF(){                               // During PLAY or PAUSE operation show the pickup
      lcd.setCursor (2,1);                     // position as absolute playing time
      lcd.print(a_trck, DEC);
      lcd.setCursor (11,1);
      lcd.print(MFS_M,DEC);
      lcd.print(":");
      if(MFS_S < 10)
      lcd.print(MFS_S,DEC);
// Auxiliary functions User Interface
void play(){
    idx = 48;                                     // pointer to play function and Play
    SendPac();                                    // from MSF location stored at idx=(51-56)
}                                                 // See also doc. sff8020i table 76
void stop(){
    idx = 32;                                     // pointer to stop unit function
    SendPac();
void eject(){
    idx = 0;                                      // pointer to eject function
    SendPac();
void load(){
    idx = 16;                                     // pointer to load
    SendPac();
void pause(){
     idx = 64;                                    // pointer to hold
     SendPac();
void resume(){
     idx = 80;                                    // pointer to resume
     SendPac();
void stop_disk(){
    idx = 176;                                    // pointer to stop disk function
    SendPac();
// Auxiliary functions PCF8475
// Set to high impedance all ports of PCF8475 interfacing to IDE.
void highZ(){
  Wire.beginTransmission(RegSel);       // address IDE Register interface
  Wire.send(255);                       // queue FFh into buffer for setting all pins HIGH
  Wire.endTransmission();               // transmit buffered data to IDE Register interface
  Wire.beginTransmission(DataH);        // address IDE DD8-DD15
  Wire.send(255);                       // as above
  Wire.beginTransmission(DataL);        // address IDE DD0-DD7
// Reset Device
void reset_IDE(){
  Wire.send(B11011111);                // Bit 5 LOW to reset IDE via nRESET
  delay(40);
  Wire.send(B11111111);                // Release reset
  delay(20);
// Read one word from IDE register
void readIDE (byte regval){
  reg = regval & B01111111;             // set nDIOR bit LOW preserving register address
  Wire.send(reg);
  Wire.requestFrom(DataH, 1);
  dataHval = Wire.receive();
  Wire.requestFrom(DataL, 1);
  dataLval = Wire.receive();
  highZ();                              // set all I/O pins to HIGH -> impl. nDIOR release
// Write one word to IDE register
void writeIDE (byte regval, byte dataLval, byte dataHval){
  reg = regval | B01000000;             // set nDIOW bit HIGH preserving register address
  Wire.send(reg);
  Wire.beginTransmission(DataH);        // send data for IDE D8-D15
  Wire.send(dataHval);
  Wire.beginTransmission(DataL);        // send data for IDE D0-D7
  Wire.send(dataLval);
  reg = regval & B10111111;             // set nDIOW LOW preserving register address
  Wire.send(reg);
  highZ();                              // All I/O pins to high impedance -> impl. nDIOW release
// Auxiliary functions ATAPI Status Register related
// Wait for BSY clear
void BSY_clear_wait(){
  do{
    readIDE(ComSReg);
  } while(dataLval & (1<<7));
// Wait for DRQ clear
void DRQ_clear_wait(){
  do{
    readIDE(ComSReg);
// Wait for DRQ set
void DRQ_set_wait(){
     do{
        readIDE(ComSReg);
     }while((dataLval & ~(1<<3)) == true);
// Wait for DRY set
void DRY_set_wait(){
     do{
        readIDE(ComSReg);
     }while((dataLval & ~(1<<6)) == true);
// Auxiliary functions Packet related
// Send a packet starting at fnc array position idx
void SendPac(){
     writeIDE (AStCReg, B00001010, 0xFF);     // Set nIEN before you send the PACKET command!
     writeIDE(ComSReg, 0xA0, 0xFF);           // Write Packet Command Opcode
     delay(400);
     for (cnt=0;cnt<paclen;cnt=cnt+2){        // Send packet with length of 'paclen'
     dataLval = fnc[(idx + cnt)];             // to IDE Data Registeraccording to idx value
     dataHval = fnc[(idx + cnt + 1)];
     writeIDE(DataReg, dataLval, dataHval);
     readIDE(AStCReg);                         // Read alternate stat reg.
     BSY_clear_wait();
void get_TOC(){
       idx =  96;                             // Pointer to Read TOC Packet
       SendPac();                             // Send read TOC command packet
       delay(10);
       DRQ_set_wait();
       read_TOC();                            // Fetch result
void read_TOC(){
        readIDE(DataReg);                      // TOC Data Length not needed, don't care
        readIDE(DataReg);                      // Read first and last session
        s_trck = dataLval;
        e_trck = dataHval;
        do{
           readIDE(DataReg);                   // Skip Session no. ADR and control fields
           readIDE(DataReg);                   // Read curent track number
           c_trck = dataLval;
           readIDE(DataReg);                   // Read M
           c_trck_m = dataHval;                // Store M of curent track
           readIDE(DataReg);                   // Read S and F
           c_trck_s = dataLval;                // Store S of current track
           c_trck_f = dataHval;                // Store F of current track
           if (c_trck == s_trck){              // Store MSF of first track
               fnc[51] = c_trck_m;             //
               fnc[52] = c_trck_s;
               fnc[53] = c_trck_f;
           if (c_trck == a_trck){              // Store MSF of actual track
               d_trck_m = c_trck_m;            //
               d_trck_s = c_trck_s;
               d_trck_f = c_trck_f;
           if (c_trck == 0xAA){                // Store MSF of end position
               fnc[54] = c_trck_m;
               fnc[55] = c_trck_s;
               fnc[56] = c_trck_f;
           readIDE(ComSReg);
        } while(dataLval & (1<<3));            // Read data from DataRegister until DRQ=0
void read_subch_cmd(){
        idx=144;                             // Pointer to read Subchannel Packet
        SendPac();                           // Send read Subchannel command packet
        readIDE(DataReg);                    // Get Audio Status
        if(dataHval==0x13){                  // Play operation successfully completed
          dataHval=0x15;                     // means drive is neither paused nor in play
        }                                    // so treat as stopped
        if(dataHval==0x11|                   // playing
           dataHval==0x12|                   // paused
           dataHval==0x15)                   // stopped
           {aud_stat=dataHval;               //
        }else{
            aud_stat=0;                      // all other values will report "NO DISC"
        readIDE(DataReg);                    // Get (ignore) Subchannel Data Length
        readIDE(DataReg);                    // Get (ignore) Format Code, ADR and Control
        readIDE(DataReg);                    // Get actual track
        a_trck = dataLval;
        readIDE(DataReg);                    // Get M field of actual MFS data and
        MFS_M = dataHval;                    // store M it
        readIDE(DataReg);                    // get S and F fields
        MFS_S = dataLval;                    // Store S value
        do{
          readIDE(DataReg);
          readIDE(ComSReg);
        } while(dataLval & (1<<3));          // Read rest of data from Data Reg. until DRQ=0
byte chck_disk(){
     byte disk_ok = 0xFF;                        // assume no valid disk present.
     idx = 128;                                  // Send mode sense packet
     SendPac();                                  //
     delay(10);
     DRQ_set_wait();                             // Wait for data ready to read.
     readIDE(DataReg);                           // Read and discard Mode Sense data length
     readIDE(DataReg);                           // Get Medium Type byte
                                                 // If valid audio disk present disk_ok=0x00
     if (dataLval == 0x02 |
         dataLval == 0x06 |
         dataLval == 0x12 |
         dataLval == 0x16 |
         dataLval == 0x22 |
         dataLval == 0x26)
         {disk_ok = 0x00;
     if (dataLval == 0x71){                      // Note if door open
        disk_ok = 0x71;
     do{                                         // Skip rest of packet
       readIDE(DataReg);
       readIDE(ComSReg);
     return(disk_ok);
void unit_ready(){                                // Reuests unit to report status
        idx=112;                                  // used to check_unit_ready
        SendPac();
void req_sense(){                                 // Request Sense Command is used to check
  idx=160;                                        // the result of the Unit Ready command.
  SendPac();                                      // The Additional Sense Code is used,
  delay(10);                                      // see table 71 in sff8020i documentation
  DRQ_set_wait();
  cnt=0;
  do{
       readIDE(DataReg);
       if (cnt == 6){
           asc=dataLval;                          // Store Additional Sense Code
       cnt++;
       readIDE(AStCReg);
       readIDE(ComSReg);
     } while(dataLval & (1<<3));                  // Skip rest of packet
void init_task_file(){
  writeIDE(ErrFReg, 0x00, 0xFF);            // Set Feature register = 0 (no overlapping and no DMA)
  writeIDE(CylHReg, 0x02, 0xFF);            // Set PIO buffer to max. transfer length (= 200h)
  writeIDE(CylLReg, 0x00, 0xFF);
  writeIDE(AStCReg, 0x02, 0xFF);            // Set nIEN, we don't care about the INTRQ signal
  BSY_clear_wait();                         // When conditions are met then IDE bus is idle,
  DRQ_clear_wait();                         // this check may not be necessary (???)
// END ####################################################################################
cry4brk
Re: Arduino ATAPI CD/ROM
by cry4brk on Wed Nov 14, 2012 6:17 pm
I also want to ask wich LCD from your shop is compatible with this project?
Thanks.
cry4brk
by cry4brk on Wed Nov 21, 2012 8:29 am
I just finished the ode* i replaced averything that was in error. Th code works but i am still confused about the SDA SCL pins and analog 4, anag 5 pins. Can please anyone explain it?
cry4brk
by tldr on Wed Nov 21, 2012 9:16 am
sda and scl are connected to a4 and a5 on the board. they were brought out to their own location presumably to simplify interfacing with i2c devices.
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
by cry4brk on Thu Nov 22, 2012 10:15 am
Can someone please check this diagrams. I have done everything exact as it is there but nothing seems to work.
With the sketch 1.0 when look in the serial monitor i see resetting IDE and Tracks 0-255 75:00 min. Somthing like this, but no response from buttons or anything else.
I didn't check the first one with LEDs
Arduino i2c
First Diagram
cry4brk
by cry4brk on Thu Nov 22, 2012 12:47 pm
This is how it looks on breadboard (without IDE cable, yet)
cry4brk
by cry4brk on Mon Feb 11, 2013 7:11 pm
Hi guys,
It's finally working!!!! The sketch 2.0 it's working just fine with CD-ROM model: LTR-40125s
cry4brk
