Winter Storm Juno: Blizzard Warning! All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
Minty boost problem
Minty boost problem
by Zak2788 on Tue Nov 20, 2012 10:39 pm
Hello, I recently got my minty boost in the mail and I put it together with no problems and I also tested all of the voltages and they were correct so I put it in an altoids tin and it worked... On an iPhone 4 for about 5 min... The battery's were brand new!!! But I also bought another new pack of battery's to try out and they did the same thing in 5 min I got the "charging not supported with this accessory" :( there is NO cold solder joints and there in NO shorts in the circuit. Please help!!!
Zak2788
Re: Minty boost problem
by adafruit_support_bill on Tue Nov 20, 2012 11:04 pm
If you post photos of the front & back of the board we will take a look. But if it is charging, your assembly is most likely OK.
What batteries are you using? Not all batteries are created equal. Check out battery recommendations here: viewtopic.php?f=15&t=22377
by Zak2788 on Wed Nov 21, 2012 12:38 am
Well that's another problem my minty boost is hot glued into the tin, is there anyway to get it out??? I am using Duracell battery's
Zak2788
by Zak2788 on Wed Nov 21, 2012 12:52 am
Also the charging icon at the top of the iPhone switches between a charging symbol and a plug symbol. Also when it's on the plug symbol I doesn't charge, and since it switches between those 2 symbols It doesn't really charge at all even though it says it is!!!
Zak2788
by adafruit_support_bill on Wed Nov 21, 2012 6:46 am
You could try heating it gently (heat-gun, hair-dryer) from the bottom of the tin.
Duracell makes many different types of batteries. Duracell-Ultra are designed for high-drain applications and generally work well in the Mintyboost.
It sounds like the phone thinks it is connected to a high-current wall-charger and is trying to charge at a higher charge rate than the Minty can keep up with. Did you short together D1 & D2 on the USB connector? The iPhone 4's usually work well in that configuration.
by Zak2788 on Wed Nov 21, 2012 9:09 pm
I shorted out the data lines and now the iPhone charges!!! But there is still a problem with the battery life on the minty boost, I tried using rechargeable energizer battery's but I get the "charging not supported with this accessory" after about 10 min :( please help. I really want to use rechargeable battery's so do I just have bad battery's?
Zak2788
by Zak2788 on Wed Nov 21, 2012 10:13 pm
Never mind it doesn't charge my iphone anymore... :( it just switches between the 2 charging symbols so fast that it doesn't charge my iphone and they are new battery's!!!
Zak2788
by adafruit_support_bill on Thu Nov 22, 2012 7:54 am
Try a different charging cable. old, extra long and/or 3rd-party cables sometimes have a significant voltage drop.
by Zak2788 on Thu Nov 22, 2012 11:51 am
I'm using the cable that came with the iPhone it's only one month old!!!
Zak2788
by adafruit_support_bill on Fri Nov 23, 2012 7:53 am
What batteries are you testing with (brand AND model)?
Measure the output voltage of the mintyboost with the phone disconnected.
Then measure it again with the phone connected & report the results.
