MCP23017 - i2c
MCP23017 - i2c
by rahatmaini on Thu Nov 29, 2012 5:32 pm
I understand that Adafruit has a library for this, however, I do not know how to assemble this and wire it correctly. Is there anyplace that has detailed instructions for utilization of this chip, I do not know much about arduino as I am very new to this.
rahatmaini
Re: MCP23017 - i2c
by tldr on Sun Dec 02, 2012 11:30 am
start with the datasheet. it's linked from the product page.
pin nine is power and pin ten is ground.
pins 15,16 and 17 are address pins. just them to ground.. if you are going to put multiple mcp23017's on the same bus you can connect some of these pins to 5v to form up to seven additional addresses.
pins 12 and 13 are your i2c bus. 12 is the clock line and 13 is data. you might want pullups on these lines, though the arduino is supposed to take care of that.
pins 21-28 will be referred to as pins 0-7 in your code. pins 1-8 on the chip will be pins 8-15 in your code.
aaaargh. what am i doing? all of this is explained in the example code in the library.
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
Re: MCP23017 - i2c
by rahatmaini on Wed Dec 05, 2012 5:23 pm
Thanks so much! Very helpful indeed, so i2c is just a fancy word for A4 and A5 on the arduino, huh? Tricky.
rahatmaini
cron
