Winter Storm Juno: Blizzard! ORDERS NOT SHIPPING TODAY. All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
How to add new boot option on uboot?
by frodo1986 on Wed Nov 28, 2012 4:29 am
I followed this tutorial to setup wifi adapter for beaglebone (angstrom),
but when everything done, I input "reboot" and return. putty is stop and no reboot.
It's looks like this following problem.
This is a solution from this tutorial, but I do not know how to add boot option on U-Boot.
Tutorial link http://learn.adafruit.com/beaglebone/wifi
Troubleshooting
If you get an error device descriptor read/64, error -71, reboot and stop the boot process with the space bar. Then add the following boot option with the follow at the U-Boot prompt
setenv bootargs irqpoll RETURN
boot RETURN
frodo1986
Re: How to add new boot option on uboot?
by adafruit on Wed Nov 28, 2012 2:02 pm
sorry, not sure we understand, does it boot if you unplug the wifi adapter?
by frodo1986 on Fri Nov 30, 2012 5:02 am
Thank you ,adafruit.
Beaglebone still disconnect after input "reboot" command even unplug the wifi adapter.
frodo1986
by frodo1986 on Fri Nov 30, 2012 5:28 am
I use putty, when reboot beaglebone, putty said "connection abort".
And then
First, I restarted putty and log in to beagle-bone again,
edited " /var/lib/connman/settings" wifi = true,
then edited " /var/lib/connman/wifi.config" likes following,
[service_home]
Type = wifi
Name = WIFI_NAME_HERE
Security = wpa2
Passphrase = WIFI_PASS_HERE
and then "root@beaglebone:~# systemctl restart connman.service"
after more than 40 seconds, input "ifconfig wlan0", it's still a lot of 0's and no inet addr(means wifi adapter dose not connect)
Please help me.
frodo1986
by adafruit on Fri Nov 30, 2012 12:13 pm
check the name, password and password type - also get close to the router. try iwlist to list all networks available
by frodo1986 on Sat Dec 01, 2012 8:26 pm
This is my wifi.config setting
[service_home]
Type = wifi
Name = "NETGEAR03"
Security = wpa2-psk
Passphrase = "slowcheese156"
I checked them couple times, all of the information are correct, but still can not use wifi adapter
frodo1986
by frodo1986 on Sat Dec 01, 2012 8:49 pm
This is wifi adapter's information(wlan0)
It seems not support WPA2-PSK
But my router does not have WPA2 mode,
Is that meaning I need change an old router or return wifi adapter?
frodo1986
by adafruit on Tue Dec 11, 2012 10:57 pm
well, we've never had anyone with this problem. you can return the wifi module for a refund by emailing support@adafruit if you dont think it works but we suggest trying a different non-adafruit wifi module as all the ones in the shop use the same chipset - you may want to try a different one from a different store.
by frodo1986 on Sun Dec 16, 2012 6:00 am
I tried every Security type including wpa wpa2 wpa2-psk. Password and username are all correct.
"we've never had anyone with this problem"???
frodo1986
by adafruit on Mon Dec 24, 2012 1:34 pm
we can't reproduce this problem. you can return the wifi module for a refund by emailing support@adafruit if you dont think it works but we suggest trying a different non-adafruit wifi module as all the ones in the shop use the same chipset - you may want to try a different one from a different store.
