Greetings, I am working on a MPPT controller for a wind turbine. I have the DC to DC converter working and I am able to manually adjust the duty cycle of the buck converter from 10 to 50 percent.
The next step of the project is to add a micro to control the duty cycle of buck converter. This is where I need help. I have to read the voltage and current at the input and output. I am using a Arduino UNO.
Max voltage is 400 Vdc at the input of the buck converter.
Buck converter max current is 20 amps.
Any help received will be greatly appreciated. What methods should I use for reading the voltage and current?
MPPT for wind turbine
- Attachments
- Buck converter with manual control for duty cycle
- FOD3180testCircuitConcept.JPG (113.96 KiB) Viewed 3610 times
- Vertical Axis Wind Turbine
- bottom.jpg (116.7 KiB) Viewed 3610 times
- F&P PMA
- DSCN2142.jpg (118.67 KiB) Viewed 3610 times
Re: MPPT for wind turbine
Hi, photos of buck converter circuit for project.
The buck converter is four 5 amp DC to DC converters connected in parallel. I am using the IRF840 mosfet. I am using a F&P axial flux motor as a 3 phase permanent magnet alternator that generates about 1 volt per RPM. Because it is possible to generate a very high voltage I have included a over voltage protection circuit.
Requesting suggestions for sensing current and reading voltage at the input and output that can interface with a UNO.
- Attachments
- over voltage protection circuit
- OVPforBuckInputVer2.JPG (44.87 KiB) Viewed 3587 times
- buck converter
- FOURparallelFOD3180testCircuitConcept.jpg (80.99 KiB) Viewed 3601 times
- Buck converter circuit
- BuckConverter&controller.jpg (127.86 KiB) Viewed 3601 times
Last edited by GoVertical0017 on Wed Dec 12, 2012 11:50 pm, edited 1 time in total.
- john444
Hi GoV,
Your VAT looks great.
I was going to suggest the Adafruit INA219 High Side DC Current Sensor.
The 20-A will not be a problem with a shunt-resistor change.
However, it will not be usable unless you were to use it on the 12-V side
of your circuit.
At 400-V you need good isolation! Maybe you would want to consider
sensing on the AC side of the alternator:
A current transformer or Hall effect will provide the Amp measurement.
A voltage-transformer for voltage.
These will provide the isolation you need and you can work with signal levels
an Arduino can handle. Especially since you do not need milli-Sec speeds.
Good Luck, John
of your circuit.
Good Luck, John
- john444
GoV,
I see you posted again before I finished composing my response to your
first post.
Why 4 buck-converters? Why not just one capable of 20-A?
John
first post.
John
Hi, I tried paralleling the mosfets and at higher amperage the board became hot, sometimes to hot. A 20 inductor is to expensive for the project. I have had very good results with the 5 amp versions, it stays cool. The max current for each board 6 amps but I am limiting the project to 15 amps total.john444 wrote:GoV,
first post.
John
This a first time attempting at this kind of project and I am searching for other project that read voltage and sense current using a UNO. Thank you for the suggestions.
- john444
GoV,
What do you think? measure high-side AC or low-side DC?
John
If each FET had it's own driver, paralleling should have worked fine.GoVertical0017 wrote:I tried paralleling the mosfets and at higher amperage the board became hot
Is it 4x as expensive as four 5-A inductors?GoVertical0017 wrote:A 20 inductor is to expensive
That is good. However, sometimes units conflict with each other. If yours don't you are good.GoVertical0017 wrote:I have had very good results with the 5 amp versions, it stays cool.
John
Hi, the only 20 amp inductor I could find cost 200.00 US. I have purchased some small current sensing transformer. The buck converters will always operate in discontinues mode so I think it will work at the AC input and the DC output. I am currently building and new permanent magnet alternator that I can operate using a hand crank then I can start testing some simple circuits and determine the max and min values. I plan to use just one buck converter to interface with the UNO and use software to multiply the values for the hole system. I will post results when available, thanks for taking a interest in the project. I am using a blocking diode at the output of each buck converter.
http://ww2.pulseeng.com/products/datasheets/P578.pdf
- Attachments
- current sense transformer
- DSCN2194.JPG (118.96 KiB) Viewed 3487 times
http://jarv.org/2009/07/home-power-monitoring/
Hi, I found this project that is very similar to what I am working on. They interface the CT to the Arduino using just a 5 Kohm resistor, can it really be that simple??????
- john444
GoV,
With a properly chosen CT and load resistor, it is simple - AC-A in / AC-V out.
Good Luck, John
Almost. I would include a couple of blue LED's or zeners to put a limit to the voltage the CTs can put out.GoVertical0017 wrote:They interface the CT to the Arduino using just a 5 Kohm resistor, can it really be that simple??????
Good Luck, John
GoV,
That's a great looking VAWT you are building! Are you documenting your project somewhere that we can take a look at?
Regards,
Josh
Regards,
Josh
http://www.vawts.net/t37175103/started- ... roto-type/
Hi, the above link is the most complete. I have been working on the project for a number years. Adding the MPPT circuit will offer the greatest benefit. Thank for the interest.
