I put up my latest modifications at: http://www.icb.se/araya/x0xb0x.html
test it at your own risk!
Altitude wrote:Seeing that you seem to have some (way more than me) insight into modding the firmware, how difficult would it be to make a midi syncd (x0x being the slave) pattern edit mode? I would love to be able to use the sequencer while slaved to my DAW midi clock
ladyada wrote:i think all you need to do is change the 'sync' variable in patternedit.c to MIDI_SYNC & make sure you dont turn on the internal tempo counter. you can look around patternplay.c to see how the sync variable is used.
ladyada wrote:look at how pattern play is done. theres only one function, but it handles all the different sorts of syncs
ladyada wrote:i think you would be best off spending more than 15 minutes looking at the firmware code if you want to understand how it works...
