Winter Storm Juno: Blizzard Warning! All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
WebIDE not starting on reboot
by Juggler00 on Fri Dec 28, 2012 11:15 pm
First... thank you -- I really appreciate all of your work on this!
First question: I looked, but could not find an official forum to post questions on the Adafruit Learning System Raspberry Pi WebIDE. Is this the best place?
Second question: I was able to successfully install the WebIDE on the latest version of Occidentalis without any problems. Likewise, was also able to log in and connect to bitbucket. However, on Pi reboot, I cannot get the WebIDE to come up again. When I tried to issue:
pi@raspberrypi-test ~/python $ sudo /etc/init.d/adafruit-webide.sh restart
[FAIL] Restarting Adafruit WebIDE server: adafruit-webide failed!
Any help?
Juggler00
Re: WebIDE not starting on reboot
by danringer on Sun Dec 30, 2012 9:51 am
Had the same problem, it happened after disk full shutdown.
Redis returned:
Short read or OOM loading DB. Unrecoverable error, aborting now.
sudo rm /var/lib/redis/dump.rdb
Corrected my problem. Only I did a full remove and reinstall of the webide before I found the problem. :oops:
danringer
by Juggler00 on Thu Jan 03, 2013 10:06 pm
Thanks for the tip... that actually came in happy another time when it wasn't working. Turns out that I don't need to reference port 3000 for my setup–it works straight off the normal URL (i.e. http://raspberypi.local.)
Juggler00
