16x2 LCD display i2c - More than one?
by pprovost on Tue Jan 01, 2013 1:24 pm
Hi all,
I just got some 16x2 display w/ shield kits. They are working nicely. I would like to daisy chain them and drive them from a single Pi. The MCP23017 controller has three address lines, so I guess I could chain up to 8 displays on the i2c bus. Is that right? Any way I can hack the PCB to set different addresses? Sure, I could put it on an external board, solder some leads to the PCB and do as I please, but I quite like the format of the display attached to the PCB.
Any advice or suggestions? Can I drive 8 16x2 displays through i2c from a single Raspberry Pi?
Paul
pprovost
Re: 16x2 LCD display i2c - More than one?
by adafruit_support_bill on Wed Jan 02, 2013 7:53 am
With a little address hacking, you should be able to drive 8 boards on the same I2C bus.
by pprovost on Wed Jan 02, 2013 9:17 am
Thanks for the answer.
So can I hack the Pi Plate to do this, or do I have to bring the MCP23017 to an outside board and do the address hacking there? I see three tabs in the back of the board. Are these the address lines?
Please advise!
Paul
Photo on 13-01-02 at 8.13 AM.jpg (57.06 KiB) Viewed 736 times
pprovost
by adafruit_support_bill on Wed Jan 02, 2013 9:24 am
I don't have one on hand to verify, but it looks like those pads are adjacent to the address pins on the chip. I'll check further to confirm.
by adafruit on Wed Jan 02, 2013 11:22 am
Those are address pins and you can cut the trace on the middle pads on one side to ground and then solder the middle pads to t he other side to adjust the address. however, its not supported and we dont have any tutorials on it, just something we tossed onto the PCBs for fun :)
by pprovost on Wed Jan 02, 2013 1:04 pm
Just as I thought. Thanks! Will have fun!
Can you draw me up where I have to cut the trace and where to solder?
Paul
pprovost
by adafruit_support_bill on Wed Jan 02, 2013 3:12 pm
If you look closely: for each set of three pads, the middle pad will be connected to one of the others. Cut the connecting trace, and use a drop of solder to bridge to the pad on the other side.
by pprovost on Wed Jan 02, 2013 5:02 pm
Got it. I guess the eyes aren't what they used to be <puts glasses on>.
Thanks for your help, sonny!
pprovost
