USB WiFi module with antenna
by delerious on Fri Jan 04, 2013 9:34 pm
Does the USB WiFi module with antenna work with the ASUS RT-N66U ? I haven't decided whether or not I want to go with a faster adapter or if the Pi could take advantage of 450Mbps.
delerious
Re: USB WiFi module with antenna
by adafruit on Sat Jan 05, 2013 3:54 pm
the wifi adapters are not high speed wifi, they should work with any wifi router but max rate is well below 450Mbps. Not sure the Pi can handle high speed either, its not a fast system.
by delerious on Sat Jan 05, 2013 9:59 pm
Thanks, I guess it wouldn't hurt to have a few different adapters to play with.
delerious
by paul66055 on Wed Feb 06, 2013 5:45 am
you can check WHZ7188.
paul66055
