HAPPY LABOR DAY - ADAFRUIT IS OPEN - ALL ORDERS PLACED AFTER 11AM ET 9/4/2015 WILL NOT SHIP UNTIL TUESDAY 9/8/2015 - READ MORE!
LEDs are HOT
LEDs are HOT
by bmxordie21 on Thu Jan 10, 2013 7:35 pm
i did the test and the green light worked. once i finished and i put the batteries in the green light didnt work and the LEDs are HOT!!!! i checked nothing is shorted out that i can see. i actually had the wires break from the battery pack. i searched on line and figured out how to fix it. i have a new battery back on there and still same thing happening the LEDs are hot. i can see one LED working thru a camcorder but only one and their all HOT! i got this kit today i paid to get it over night and it cost me 50 bucks. i wanted to use it today and now im stuck. ANY IDEAS!!!!????? thanks, james
bmxordie21
Re: LEDs are HOT
by adafruit_support_bill on Thu Jan 10, 2013 8:36 pm
Post photos of the front and back of the board so we can check your assembly.
Re: LEDs are HOT
by bmxordie21 on Thu Jan 10, 2013 9:29 pm
I didn't mean to repost but I'll try to take pics
How do you post pics
bmxordie21
Re: LEDs are HOT
by adafruit_support_bill on Thu Jan 10, 2013 9:40 pm
Use the "upload attachment" tab below the message editing window. Re-size your photos to about 800x600 if possible.
Re: LEDs are HOT
by bmxordie21 on Thu Jan 10, 2013 10:21 pm
the wires for the batterys were on and then i was having problems then they broke off
bmxordie21
Re: LEDs are HOT
by bmxordie21 on Thu Jan 10, 2013 10:23 pm
my soldering isnt the best but its my first project
bmxordie21
Re: LEDs are HOT
by adafruit_support_bill on Fri Jan 11, 2013 7:25 am
There are a couple solder joints that look a little suspicious, but nothing that would account for the LEDs heating up. Check the markings on the transistors. Q5 should be different than Q1-4.
Re: LEDs are HOT
by bmxordie21 on Fri Jan 11, 2013 3:26 pm
I used a magnifying glass and none of the solders are touching each other and I check the Q5 is in the right spot
bmxordie21
Re: LEDs are HOT
by adafruit_support_bill on Sat Jan 12, 2013 11:52 am
Are all the LEDs getting warm? Or only the one that lights up? Is anything else on the board getting hot?
I don't see any short circuits. But you have several solder joints where the solder has not flowed well onto both the pin and the solder pad. Check this guide for common soldering problems and how to fix them. http://learn.adafruit.com/adafruit-guid ... n-problems
Re: LEDs are HOT
by bmxordie21 on Sat Jan 12, 2013 11:28 pm
I fixed a lot of my solder points but still all the LEDs and the four NPN transistors are heating Up
bmxordie21
Re: LEDs are HOT
by adafruit_support_bill on Sun Jan 13, 2013 7:13 am
What were you using to power this? The NPN transistors and diodes connect directly between VCC and GND. Even a short circuit on the board could not cause them to overheat with the supplied battery pack. The only way to cause these to overheat is to put more than 5v through it. This will damage the board.
Re: LEDs are HOT
by bmxordie21 on Mon Jan 14, 2013 2:58 am
My wire broke off and I searched thru other peoples issues and adafruit support said to scratch off the green part next to the holes and solder on the copper neutral on the front and positive on the back and I used two AA battery pack
bmxordie21
Re: LEDs are HOT
by adafruit_support_bill on Mon Jan 14, 2013 10:25 am
Do you have a multimeter? If so, measure the current from your battery pack when powering the TV-B-Gone.
http://learn.adafruit.com/multimeters/current
Re: LEDs are HOT
by bmxordie21 on Mon Jan 14, 2013 8:46 pm
What should it be?
bmxordie21
Re: LEDs are HOT
by adafruit_support_bill on Mon Jan 14, 2013 9:53 pm
I haven't measured one, but from the circuit design I'd estimate around 200mA.
