CYBER MONDAY SALE - Get 15% off! Use the code CYBERMONDAY15 on checkout *some restrictions apply.
xoxbox problem ableton
Moderators: altitude, adafruit_support_bill, adafruit, mome rath, phono
by xonec on Wed Jan 23, 2013 7:02 pm
I've set my xoxbox in midi play mode. everything works fine and plays in sync with my beats, but it's like the sound comes out of the midi track(??) and not from my audio track I've created (ext in). Also when I adjust the master of ableton the xoxbox stays at the same volume. So I have to adjust the volume on the xoxbox. I've tried everything I think but nothing seems to help. It's like my midi channel is monitoring or something.
Thanks in advance!
Re: xoxbox problem ableton
by DjunaSaurus on Sun Jan 27, 2013 1:43 pm
You can't change the volume through midi, and I'm not sure why this would be a problem?
I'm also not sure what you mean with your first issue - you mean you can't hear the audiofile you've recorded?
by roxxx303 on Mon Jan 28, 2013 11:06 am
Hi xonec,
I don't know if I understood your problem correctly, but for me it sounds that your "monitoring" is switched on on your audio-in device!
Look on your audio-device if there is a hardware-switch for direct monitoring!
Switch it off to only hear the recording-signal in Ableton.
Hope that helps!
