Weatherproof TTL Serial JPEG Camera with NTSC Video and IR LEDs
by anibalr on Fri Jan 25, 2013 6:29 pm
I am having difficulty using the Adafruit-VC0706 file. I followed the instruction to rename the file to Adafruit-VC0706 and the put it in the library. I see all the files but I am gettig errors when I upload the file to arduino. When I go to file, example I do see the Adafruit-VC0706.
ERRORS:
Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
Adafruit_VC706 does not name a type
anibalr
Re: Weatherproof TTL Serial JPEG Camera with NTSC Video and IR LEDs
by franklin97355 on Fri Jan 25, 2013 6:48 pm
In one place you are using a dash and in another an underscore. Was this a typo or are you actually doing that? The file also have to be in a folder of the correct name.
franklin97355
by anibalr on Fri Jan 25, 2013 7:25 pm
1) I downloaded the Adafruit VC0706 Arduio library Github respository
2) After the file is uncompressed the folder is rename to Adafruit_VC0706
3) I went to the arduino library and place the Adafruit_VC0706 folder into libraries folder
anibalr
by adafruit_support_bill on Sat Jan 26, 2013 7:17 am
In the screen shot, it shows up with the dashes instead of the underscore. And it looks like you have one level too many.
by anibalr on Sat Jan 26, 2013 1:35 pm
OH Ok I got the library in the proper folder ad it compile as expected. However I am unable to take pictures. First, downloaded the VC0706 Comm Tool and followed the instruction and I see video out from the TV. I just dont see any image comming out of the VC0706 Comm Tool.
anibalr
by adafruit_support_bill on Sun Jan 27, 2013 7:25 am
How big is the JPEG file that was saved?
by anibalr on Sun Jan 27, 2013 8:17 pm
I dont know, how can I find out.
anibalr
by adafruit_support_bill on Sun Jan 27, 2013 8:52 pm
If you are following the tutorial: http://learn.adafruit.com/ttl-serial-ca ... g-commtool
When you click "Stop FBuf" and "Sel File" you tell it where to save the file. Look at the file that was saved and see how big it is.
by anibalr on Sun Jan 27, 2013 10:42 pm
I am able to save it, but it is empty no picture at all.
anibalr
by adafruit_support_bill on Mon Jan 28, 2013 7:06 am
How big is the file?
by anibalr on Mon Jan 28, 2013 1:45 pm
I am getting a "Cmd time out error" see attach for more info...
According to the instruction "There's no way to change
the image size from this program (easily) but we can do it using the Arduino sketch so just try it
out here to start."
Cmd time out.jpg (238.07 KiB) Viewed 1517 times
anibalr
by adafruit_support_bill on Mon Jan 28, 2013 2:07 pm
Which command is timing out?
by anibalr on Mon Jan 28, 2013 5:40 pm
If you see the attachment you see what I am saying.
anibalr
by adafruit_support_bill on Mon Jan 28, 2013 6:32 pm
I can see that a command timed out, but I cannot see what command it was.
If you want us to help you, you have to answer the questions we ask.
by anibalr on Mon Jan 28, 2013 7:23 pm
Ok, when I press
Get Version -> I get Cmd time out
In the Fbuf control panel
Stop CFbuf -> I get Cmd time out
Stop NFbuf -> I get Cmd time out
anibalr
cron
