Winter Storm Juno: Blizzard Warning! All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
Trouble with wlan0 on occidentalis 2
by doggitz on Sat Dec 22, 2012 1:54 am
I installed occidentalis 2 exactly as instructed by the web site. When I type "sudo ifconfig" to look at what is up, I do not see the wlan0. I looked at the web and found a few people using Raspian say that they were having trouble getting wlan0 to come up on boot and recommended using the command "sudo ifconfig wlan0 up". I tried this but to no avaiul. I did go back and check my raspi-config and did re-enable the sshd.
I am using a wired ethernet and MIdori works properly.
Would appreciate any help
Doggitz
doggitz
Re: Trouble with wlan0 on occidentalis 2
by tldr on Sat Dec 22, 2012 1:09 pm
what wifi adapter are you using? is it plugged in to the pi or to a usb hub? is there an led lit on it?
i have this guy and it's got a blue led that's on solid if it's powered but not configured and blinks when it's working.
do you see the device when you type lsusb at the command line?
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
by doggitz on Sun Dec 23, 2012 1:18 am
I am using the wireless usb adapter sold by adafruit - the ourlink model. I am also using a 4 port powered usb hub built by dynex. I have nothing elese plugged into the powered usb hub. When i issue the lsusb command as you suggested device 1 is the linux foundation 2.o root hub and 2-4 are standard microsystems. Device 5 is the 4 port hub, device 6 is morotola pcs ( I am using an Atrix keyboardband monitor) device 7 says Belkin and finally device 8 is the wlan adapter.
I have tries the sudo ifcong wlan0 up command with no luck
Would appreciate any suggestions
doggitz
by adafruit on Sun Dec 23, 2012 3:06 pm
detach the usb hub
plug the wifi directly in.
post up the exact output from: sudo ifconfig -a
by phedlund on Tue Jan 29, 2013 4:01 pm
I have the same situation. I am running occidentails2 using the Miniature WiFi (802.11b/g/n) Module from Adafruit. Here is the output from my sudo ifconfig -a
I also tried the sudo ifconfig wlan0 up without any effect.
I have tried with and without a powered external hub
The Pi is powered by a 5.25 volt 1a power supply (from Adafruit)
eth0 Link encap:Ethernet HWaddr b8:27:eb:be:2e:9f
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
wlan0 Link encap:Ethernet HWaddr 00:e0:4c:10:46:f3
phedlund
