Driving DC motors with Adafruit motor shield V1.1
by gwd on Mon Jan 28, 2013 9:58 pm
How do I find or write code to run 4 small DC motors at one time?
gwd
Re: Driving DC motors with Adafruit motor shield V1.1
by adafruit_support_bill on Mon Jan 28, 2013 10:15 pm
We have not manufactured or sold the V1.1 shield for several years now. Where did you purchase your shield?
by gwd on Tue Jan 29, 2013 9:48 am
I purgchased the Motor Shield Kit v1.1 from Makershed.com in Dec 2012
gwd
by adafruit_support_bill on Tue Jan 29, 2013 9:57 am
Hmmm. MakerShed should have the V1.2 boards. Can you post a photo of the board?
by Arctic_Eddie on Tue Jan 29, 2013 10:10 am
I have a motor shield kit in my hand that I bought last year. The package says V1.1 with a web link:
http://adafruit.com/products/81
This shows a photo of your latest kit but it shows V1.0. My board is not the same as your photo and says V1.2.
What is the latest version?
Arctic_Eddie
by adafruit_support_bill on Tue Jan 29, 2013 10:48 am
1.2 is the latest version. It should be a blue board. Sounds like maybe the package labeling is a source of confusion. The product description should be updated too.
Thanks Arctic_Eddie!
by adafruit_support_bill on Tue Jan 29, 2013 10:54 am
Back to the original question:
You need to declare 4 different motors, one for each of the motor channels. Then you can command each motor by name.
#include <AFMotor.h>
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Motor test!");
  // turn on motor
  motor1.setSpeed(200);
  motor2.setSpeed(200);
  motor3.setSpeed(200);
  motor4.setSpeed(200);
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
void loop()
  uint8_t i;
  Serial.print("tick");
  motor1.run(FORWARD);
  motor2.run(BACKWARD);
  motor3.run(FORWARD);
  motor4.run(BACKWARD);
  for (i=0; i<255; i++)
    motor1.setSpeed(i);
    motor2.setSpeed(i);
    motor3.setSpeed(i);
    motor4.setSpeed(i);
    delay(10);
by gwd on Tue Jan 29, 2013 9:05 pm
My board is blue but the package says v1.1. I tried to post a picture but It did not post. I will try again. I uploaded the code that you suggested and got motors 1 and 2 to run but not motors 3 and 4. Your help is much appreciated in getting me headed in the right direction.
gwd
by gwd on Tue Jan 29, 2013 9:07 pm
Hopefully, these pictures will post this time
gwd
by adafruit_support_bill on Wed Jan 30, 2013 7:20 am
OK. That is a 1.2 board. The version number is printed just above the M1,M2 motor terminal block. You have the L293D for M3-M4 installed backwards. The notch needs to line up with the one on the silkscreen.
by gwd on Wed Jan 30, 2013 11:38 pm
I re-installed the L293D correctly but motors 3 & 4 still did not work . I then rotated the two to make sure it was not damaged, but I still get the same result. I really appreciate your time, suggestions and prompt replies.
gwd
by adafruit_support_bill on Thu Jan 31, 2013 7:21 am
It is hard to see in the photos, but you have a few solder joints that appear a little 'solder-starved' - including a couple of pins on that L293D. Take a close look and touch up any joints that look suspicious.
http://learn.adafruit.com/adafruit-guid ... n-problems
