ADS_1115 sampling rate
by ptc on Fri Jan 25, 2013 6:51 pm
I am trying to use the ads1115 adc to collect data from three inputs. I am using the ads1x15 library for Arduino. Using the example code, I get ~38 SPS. How do I increase the sampling rate?
thanks,
ptc
Re: ADS_1115 sampling rate
by adafruit_support_mike on Sat Jan 26, 2013 12:00 am
You'll want to use the function ADS1115::setRate(). Send it one of the following values from the header file:
#define ADS1115_RATE_8              0x00
#define ADS1115_RATE_16             0x01
#define ADS1115_RATE_32             0x02
#define ADS1115_RATE_64             0x03
#define ADS1115_RATE_128            0x04 // default
#define ADS1115_RATE_250            0x05
#define ADS1115_RATE_475            0x06
#define ADS1115_RATE_860            0x07
by ptc on Sat Jan 26, 2013 3:50 am
Thank you for the quite reply.
However, I did not see this function in the ADS1X15 library that I downloaded from https://github.com/adafruit/Adafruit_ADS1X15. Is there a newer version?
ptc
by adafruit_support_bill on Sat Jan 26, 2013 8:15 am
Can you post the sketch you are using?
by ptc on Sat Jan 26, 2013 2:11 pm
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads1115;
void setup(void)
  Serial.begin(115200);
  Serial.println("Hello!");
  Serial.println("Getting single-ended readings from AIN0..3");
  Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV)");
  ads1115.begin();
void loop(void)
  int16_t adc0, adc1, adc2, adc3;
    adc0 = ads1115.readADC_SingleEnded(0);
    adc1 = ads1115.readADC_SingleEnded(1);
    adc2 = ads1115.readADC_SingleEnded(2);
    Serial.print(millis());
    Serial.print(",");
    Serial.print(adc0);
    Serial.print(",");
    Serial.print(adc1);
    Serial.print(",");
    Serial.print(adc2);
    Serial.println(",");
ptc
by adafruit_support_bill on Sat Jan 26, 2013 5:39 pm
You have about 18mS worth of serial printing in your loop. That will slow things down a bit.
by retrolefty on Sat Feb 02, 2013 12:56 pm
adafruit_support wrote:You have about 18mS worth of serial printing in your loop. That will slow things down a bit.
Even with the fully buffered interrupt driven serial transmission that the arduino hardware serial now has?
Lefty
retrolefty
by zaman on Tue Sep 17, 2013 5:23 pm
Hi, It looks like this post is really old but I am having a similar problem. I am using arduino and the Adafruit_ADS1X15 library. I am getting around around 100hz if reading from 1 channel, and 33hz if reading 4 channels(or 130Hz). My goal is to get 200hz and reading 4 channels or 800 samples per second total. I have posted this on the arduino boards as well and it looks the same here that when people post this question everyone gets hung up on the serial print time. I don't buy and it and these rates are for the following code(the 4 channel situation is the same just add 3 more single ended reads from each channel). Now obviously I'm going to add more to this but this is just a proof of sampling rate. I did this as well without the single read and the serial.println(millis()); takes about .5ms or 2000hz.
#include <Wire.h>
void setup(void)
  ads1115.setGain(GAIN_TWO);
  ads1115.begin();
void loop(void)
  ads1115.readADC_SingleEnded(0));
  Serial.println(millis());
zaman
