I'm testing the MTK3339 GPS with Arduino Leonardo and is not working.
I followed this tutorial: http://learn.adafruit.com/adafruit-ulti ... ter-wiring, I load a 'blank' sketch into the Arduino, but when I open the serial monitor from the Arduino IDE I don't view any data.
Attached is a picture with my wiring
Can you help me with my problem?
Thanks!!
- fran.manez
- Attachments
- wiring.JPG (51.93 KiB) Viewed 3716 times
- adafruit_support_rick
Re: MTK3339 GPS with Arduino Leonardo
Looks right. Have you set the data rate in the serial monitor to 9600?
Try different jumper wires or different breadboard locations. Sometimes the connections can be a little finicky.
- dennisma
I don't have this particular GPS but doesn't the TX pin on the Arduino go to the RX pin on the GPS (and Arduino's RX go to the GPS's TX).
From the pic it looks like RX is going to RX and TX is going to TX (which is normally wrong).
Or maybe it is just late on Friday and I can't tell...
- fran.manez
driverblock,
I set the the data rate in the serial monitor to 9600. And I have changed the jumper wires and the breadboard locations... and not working yet.
It's possible that the GPS module is damaged or defective?
I tried to load the other examples in the tutorial and not working.
The GPS fix light flashes every second. Then changes to flash every 15 seconds ... this is correct?
______
dennisma,
the connections are correct. They are the same as in the tutorial:
// Connect VIN to +5V
// Connect GND to Ground
// Connect GPS RX (data into GPS) to Digital 0
// Connect GPS TX (data out from GPS) to Digital 1
______
dennisma,
- dennisma
Yes, but that appears incorrect. Digital 0 is RX and it always connects to TX on a GPS. The Transmit (TX) line of the GPS must connect to the Receive (RX) of the Arduino. That is normally how GPS's hook upfran.manez wrote:driverblock,
If you do not believe me (and why should you?), look at Adafruit's wearable GPS wiring instructions at http://learn.adafruit.com/flora-wearabl ... ook-up-gps
It says: "Likewise connect RX to TX and TX to RX..."
See the wiring from same page:
Now look at your board. You have Digital 0 (RX) connected to GPS RX. It won't work.
Also look at this wire hookup from the net. Notice that Digital Pin 0 (RX) is connecting to TX. Also note that Pin 1 is not connected because it doesn't need to be. You never talk to the GPS, you just receive the NMEA sentences from it.
Dennisma is correct. The picture in the tutorial shows the wrong wiring on Tx and Rx. Swap the green and orange wires on the Leonardo.
Meanwhile, I'll see about fixing the tutorial...
- dennisma
Always good to know I am not going crazy... yet.driverblock wrote:Dennisma is correct. The picture in the tutorial shows the wrong wiring on Tx and Rx.
fran.manez let us know how it works out for you.
Wait... wait a minute....
We're all wrong!!
@dennisma - the tutorial step the OP is doing calls for Direct Writing to the computer. For this purpose, wiring TX to TX and Rx to RX is actually correct, since the idea is to bypass the ATmega328 and go straight to the USB interface chip.
@fran.manez - you are using a Leonardo, which doesn't have a separate USB interface chip. The Direct Wiring to Computer step cannot be done with a Leonardo, since it relies on a trick of the Uno (and earlier) hardware design.
Just skip this step and go on to the next one.
We're all wrong!!
- dennisma
Ha! You are correct. I should have looked at what the Tutorial was doing. It was all empty code.driverblock wrote:We're all wrong!!
Dang Leonardo's and their wacky serial. Sorry fran.manez
@fran.manez - I just went through the tutorial, and the example sketches on GitHub are not compatible with the Leonardo. The GPS library works - it's just an issue with the way the example sketches are written.
I plan to update the sketches for the Leonardo over the weekend. Thanks for your patience.
Meanwhile, I hacked up a quick and dirty fix to the echo sketch, which you are welcome to try (attached).
All you have to do is swap the connections to TX and RX:
GPS Tx -> Leo RX1
GPS Rx -> Leo TX1
Set the serial monitor for 57600.
GPS Tx -> Leo RX1
GPS Rx -> Leo TX1
- fran.manez
@driverblock - great!! is working now!! thank you very much. Your code working perfectly.
Let me know when you update the sketches for the Leonardo
@dennisma - thanks for your help
Example sketches for Leonardo have been added to the Adafruit GPS LIbrary
Maybe I can get some help as well.
I'm also currently using this particular GPS. However, I want to format the text I receive from the command
Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
The output is in this form = 5533.7563N, 1300.2744E.
I would like it to be in this form = 55 33.7563N, 13 00.2744E.
Any suggestions?
Best Regards
Any suggestions?
Best Regards
Try this:
Serial.print("Location: ");
int GPSdegrees = (int)(GPS.latitude/100);
Serial.print(GPSdegrees); Serial.print(" "); Serial.print(GPS.latitude-GPSdegrees, 4); Serial.print(GPS.lat);
Serial.print(", ");
GPSdegrees = (int)(GPS.longitude/100);
Serial.print(GPSdegrees); Serial.print(" "); Serial.print(GPS.longitude-GPSdegrees, 4); Serial.println(GPS.lon);
