I2C LCD Issues
I2C LCD Issues
by k1i on Sun Feb 03, 2013 4:40 pm
I purchased the negative LCD + I2C board kit from Adafruit, and had some general questions about the operation of the I2C bus and the MCP23017.
The LCD works perfectly, the buttons work well, but, I run into an issue when I use multithreading to read button state and write to the LCD at the same time.
Is anyone else doing this successfully? When I have button states being checked in their own thread and make write ops (message, backlight, clear, etc), the screen fills with gibberish and the LCD becomes non-responsive until I re-initialize it.
Is there some kind of a trick to enable I2C transactions? Is there no way to have multiple threading with this? Do I need a queue?
All help is appreciated
K
k1i
Re: I2C LCD Issues
by adafruit_support_bill on Mon Feb 04, 2013 7:05 am
i2c is a serial interface. If you have multiple threads talking to it, the commands will get interleaved and the results are scrambled. There are many strategies for dealing with device I/O in a multi-threaded system. If you already have the code written, the simplest thing would be to add a mutex to gate access to the device.
