G is for GROUND! The latest Circuit Playground is here!
Can't get my XBees communicating again
by kcranley on Mon Feb 11, 2013 7:40 am
Hi
I have one XBee (S1) connected to an Arduino R3, powered by my PC, and running a sketch which receives signals from another XBee (S1), connected to a Boarduino, powered by a laptop, and connected to a PIR sensor, and running a sketch which sends signals to the first XBee.
I had this working on my desktop, intending to put the Boarduino/PIR sensor in a remote place eventually.
However, when the laptop decides to go to sleep, the Boarduino power goes off, and I can usually get the whole thing going again after a lot of wire swapping, resetting etc, but just at the moment, the XBees are not communicating.
Can you suggest a simple way of restoring communication if the Boarduino/PIR combination should temporarily lose power?
KC
kcranley
Re: Can't get my XBees communicating again
by adafruit_support_bill on Mon Feb 11, 2013 8:30 am
What kind of wire-swapping do you have to do? It should just come up running.
by kcranley on Mon Feb 11, 2013 8:52 am
When the communication doesn't resume, I try a lot of things. I replace the Boarduino sketch with the Bare Minimum sketch - to do this, RX/TX needs to be reversed. This seems to be necessary to run X-CTU, to determine if the XBees actually work, and having done that, my sketches need to be re-uploaded, so to return to the original wiring, the RX/TXs need to be reversed again.
Apologies if this is a bit jumbled
kcranley
by adafruit_support_bill on Mon Feb 11, 2013 9:25 am
So you change the wiring & sketch to verify that the XBee is still working, then put it back to the way it was? Normally, the Boarduino should just come up running on power-up. It is possible that there might be some issue with the power-up timing of the XBee vs the Boarduino, but I would expect that a simple reset would get you running again.
Do you have a simple wall-wart or battery supply for the Boarduino/XBee? There might be something funky in the way your laptop's USB port powers up.
by kcranley on Mon Feb 11, 2013 10:23 am
Yes - that's right - I put it back the way it was when it worked. I now have it on an external supply, and that makes no difference.
kcranley
by adafruit_support_bill on Mon Feb 11, 2013 12:52 pm
Are you sure the problem is at the Boarduino end? Maybe it is the receiving side that needs to be reset to re-sync.
by kcranley on Mon Feb 11, 2013 1:05 pm
How do you do that? The receiving end is another XBee (also on Adafruit adapter) with an Arduino Uno R3, powered by my desktop Windows PC.
kcranley
by adafruit_support_bill on Mon Feb 11, 2013 1:38 pm
Press the reset button on the Uno.
by kcranley on Mon Feb 11, 2013 1:48 pm
OK - I've been doing that too - still nothing
kcranley
by adafruit_support_bill on Mon Feb 11, 2013 1:53 pm
Do the XBee leds indicate any transmission activity when the Boarduino powers up?
by kcranley on Mon Feb 11, 2013 2:13 pm
No - the red lights don't come on - except every few minutes the receive end's red light comes on but only for a few seconds, and not in response to a reset. The green lights on both XBees are blinking.
kcranley
by adafruit_support_bill on Mon Feb 11, 2013 3:29 pm
Post the code you are using.
by kcranley on Tue Feb 12, 2013 5:16 am
Here is the sketch on the Boarduino for detecting PIR signals and sending a stream of H's or L's depending on whether the PIR signal is high or low: (There is some redundant code for a Real Time Clock which hasn't been included yet).
// PIR motion detector with LED indicator
// Status info by XBee to PC
// 11 Jan 2013
#include <Wire.h>
#include <RTClib.h>
#include <SoftwareSerial.h>
RTC_DS1307 RTC;
SoftwareSerial XBSerial = SoftwareSerial(2, 3);
int PIRpin = 4;      // digital pin 4 for PIR
int LEDpin = 13;   // digital pin 13 for LED
int PIRval;             // PIR HIGH or LOW value
  pinMode(LEDpin, OUTPUT);    // set the LED pin as ouput
  pinMode(PIRpin, INPUT);     // set the PIR pin as an input
  // Setup SoftwareSerial port
  XBSerial.begin(9600);
  Serial.begin(9600);
  XBSerial.println("Setup finished.");
  if (! RTC.isrunning())
    Serial.println("RTC is NOT running!");
  PIRval = digitalRead(PIRpin);    // read PIR
  if (PIRval == HIGH) {
    Serial.print("H");
    digitalWrite(LEDpin, HIGH);    // LED ON
  else {
    Serial.print("L");
    digitalWrite(LEDpin, LOW);     // LED OFF
  delay(100);
and here is the sketch on the Arduino for receiving XBee signals and outputting h's or l's depending on what it has received from the remote PIR:
//XBeeReceive
//Sketch for receiving XBee transmissions from RemotePIR on remote
//Boarduino connected to a PIR and XBee
//KC  11-Jan-13
int LedPin = 13;
int speakerPin = 9;
  Serial.begin(9600);
  pinMode(LedPin, OUTPUT);
  pinMode(speakerPin, OUTPUT);
void playTone(int tone, int duration){
  for (long i = 0; i < duration*1000L; i += tone*2){
    digitalWrite(speakerPin, HIGH);
    delayMicroseconds(tone);
    digitalWrite(speakerPin, LOW);
  if (Serial.available())
  int data = Serial.read();
    if (data == 'H')
      //Serial.println("Somebody's in the garden");
      digitalWrite(LedPin, HIGH);
      Serial.write("h");
      playTone(956, 50);
      playTone(500, 50);
      playTone(250, 50);
      playTone(125, 50);
    else if (data == 'L')
      digitalWrite(LedPin, LOW);
      Serial.write("l");
    else
  //delay(10);
kcranley
by adafruit_support_bill on Tue Feb 12, 2013 8:24 am
On the Boarduino side, you have XBeeSerial and Serial. After setup, you only write the Serial.
Serial.print("H");
Serial.print("L");
by kcranley on Wed Feb 13, 2013 5:52 am
Sorry - my code is messy because I have been trying different things, and I'm still learning the basics. I am confused as to whether I should be using Serial or XBSerial. What I want to do is to send the characters "L" or "H" from the PIR/Boarduino/XBee (SENDER) powered by the Laptop to the Arduino/XBee/PC (RECEIVER) so that I can see either "l" or "h" on the PC serial monitor, and a LED comes on when the PIR goes high. I want to see either "L" or "H" on the Laptop serial monitor also, so that I can see that everything is doing what it's supposed to be doing.
Currently, using only XBSerial on the SENDER and only Serial on the RECEIVER, it is doing what I want. However, when I move the SENDER away from the Laptop, and power it with an external source, it no longer transmits.
Can you suggest what I might do to have the SENDER placed remotely, on external power, so that I can see on the PC when the PIR has been activated?
kcranley
