Power issues with new Pi?
by SimpleSimon on Mon Feb 18, 2013 1:48 am
I am encountering some problems with my new Pi Rev B. It was working fine, but it started having issues where it would only illuminate the red LED. I tried a few known good SD and even re-imaged one. I tried using my serial cable, USB and bench top power supply to eliminate it as a possible problem. Voltage across the test ports was 4.2 or low. Any attempts to power the unit will make the voltage regulator hot to the touch. At this point, I am hoping for a poly resistor reset.
I was using a wi-fi adapter, keyboard and mouse and HDMI. Tests were done without anything attached. Any thoughts on what to try next? It won't even turn in at this point.
SimpleSimon
Re: Power issues with new Pi?
by adafruit_support_rick on Mon Feb 18, 2013 11:10 am
Have you tried powering it without the SD card installed?
by SimpleSimon on Mon Feb 18, 2013 11:58 am
I will give that a go this evening. It nagged on me last night! :lol: Hard to fall asleep when you have a problem in front of you. I attempted to power it up again this morning with a more robust USB cable, still no power indication other than an extremely hot voltage regulator.
SimpleSimon
by adafruit_support_rick on Mon Feb 18, 2013 12:13 pm
Have a look at the RPi troubleshooting page, too.
by SimpleSimon on Mon Feb 18, 2013 9:48 pm
Voltage across test points is 3.97.
Tried booting without SD card. No lights.
SimpleSimon
by adafruit_support_rick on Mon Feb 18, 2013 9:56 pm
Do you get that voltage without the SD card inserted? You said you tried several different SD cards, so it sure sounds like the Pi is toast. Please email support@adafruit.com with a link to this thread to arrange a replacement.
