Reverse TV B Gone
Reverse TV B Gone
by woor on Thu Jun 30, 2011 12:50 pm
It is possible to modify a TV B Gone and use it to turn ON all the tv?
Has anyone the codes for turn ON televisions?
Thank you very much.
Alessio
woor
Re: Reverse TV B Gone
by adafruit on Thu Jun 30, 2011 1:56 pm
woor wrote:It is possible to modify a TV B Gone and use it to turn ON all the tv?
Alessio
the on and off codes are usually the same, so it already turns on and off tvs.
cheers,
by Agent24 on Sun Jul 03, 2011 7:32 pm
adafruit wrote:the on and off codes are usually the same, so it already turns on and off tvs.
cheers,
I wonder if this might not be the case in some situations though?
I can turn my friend's old Sony off with my TV-B-Gone but it can't turn it back on again.
My own TV however (Philips) turns on and off with the TV-B-Gone.
Agent24
by adafruit on Sun Jul 03, 2011 8:30 pm
cheers,
some tvs could be different, yes.
thanks,
by vxbinaca on Fri Jul 08, 2011 2:34 am
My understanding of TV's is, when you plug them in the remote receiver circutry is powered all the time and the "Power" button merely inverts the power status of the TV but default is is off and watching to the IR code to turn it on.
Depends on the TV's remote firmware. Some seem to kick on/off with multiple sets of codes.
vxbinaca
by CharString on Fri Jul 06, 2012 5:54 pm
Some TV's turn on by picking a channel. And the power code doesn't toggle, but just turns it off.
CharString
by adafruit_support_rick on Fri Jul 06, 2012 6:08 pm
In most cases, IR codes sets include POWER-ON, POWER-OFF, and POWER-TOGGLE as distinct codes. The remotes that come with TVs generally implement POWER-TOGGLE, and it would make sense that the TV-B-Gone would only implement POWER-OFF codes (to avoid toggling).
by dancline on Thu Aug 30, 2012 9:02 pm
I just assembled my first TV-B-Gone, and it both turns off and turns on my (ahem) older Samsung TV.
Great kit! Can't wait to try it out at my local sports bar!!
dancline
by Keviocyn on Mon Feb 18, 2013 5:03 pm
Hello
I just put together my first TV B gone! and it works. However, I think I may have reversed something, as when I hold the button down, it turns off, and when I do not, the green LED flashes and works. Since I am new, I re-read all instructions and I can not see what I have done wrong.
All in all I am quite happy with it, I just need to figure out how to reverse it so it works when the button is depressed.
Thanks again
Kevin
Keviocyn
by adafruit_support_rick on Mon Feb 18, 2013 5:11 pm
If I'm understanding you correctly, that's the way it's supposed to work:
Press the button once. Don't hold the button down! It will just keep resetting itself. The codes start to transmit once you release the button.
The indicator LED will blink for every code it sends. Keep the TV-B-Gone pointed at your target until it turns off. The 4 infrared LEDs will not blink visibly because human eyes can't see infrared light.
When the TV-B-Gone is finished, the indicator light will blink quickly a few times and then stop.
by Keviocyn on Mon Feb 18, 2013 5:26 pm
OK, awesome! I was thinking that it was permanently stuck on, as I did not wait for the complete cycle to finish.
Thanks for the quick reply!
Kevin
Keviocyn
