WiFi install problem
by rdiederich on Wed Feb 20, 2013 12:29 am
While trying to install the updates for the USB WiFi. I encountered to following error. It appeared that all the firmware installed correctly but when I did a reboot prior to running "ifconfig wlan0" as per the instructions I received the errors listed below. I have attempted the total install/upgrade multiple times and get the same error.
Can anyone please provide me an approach to resolve this problem?
root@beaglebone:~# reboot
[ 479.696929] omap_wdt: Unexpected close, not stopping!
Sending SIGTERM to remaining processes...
[ 480.153625] INFO: task systemd-udevd:73 blocked for more than 120 seconds.
[ 480.160797] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
Sending SIGKILL to remaining processes...
Hardware watchdog 'OMAP Watchdog', version 0
Unmounting file systems.
Unmounted /dev/mqueue.
Unmounted /sys/kernel/debug.
Disabling swaps.
Detaching loop devices.
Detaching DM devices.
[ 600.163604] INFO: task systemd-udevd:73 blocked for more than 120 seconds.
[ 600.170776] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
[ 720.173553] INFO: task systemd-shutdow:1 blocked for more than 120 seconds.
[ 720.180816] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
[ 720.189056] INFO: task systemd-udevd:73 blocked for more than 120 seconds.
[ 720.196228] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
[ 840.203552] INFO: task systemd-shutdow:1 blocked for more than 120 seconds.
[ 840.210815] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
[ 840.219055] INFO: task systemd-udevd:73 blocked for more than 120 seconds.
[ 840.226226] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
message.
rdiederich
Re: WiFi install problem
by adafruit_support_rick on Wed Feb 20, 2013 11:56 am
That's the watchdog timer refusing to close. The driver has been compiled with an option to prevent it from accepting close requests (see line 182). Have you done anything special with the watchdog?
by rdiederich on Thu Feb 21, 2013 1:08 pm
Thanks for the reply,
I have not changed any code. I was following the instructions on page 16 of the http://learn.adafruit.com/beaglebone document which installs the linux-firmware-rtl8192-cu code which I believe is the code that enables the usb wifi adapter. I have tried re running the instruction at least 3 time with the same results. I will try again today and see what else I can fine and port the results.
rdiederich
