Device signature = 0x000000 from Avrdude to ATMega16u4
by Stpn on Sun Mar 03, 2013 11:44 pm
Hi I am trying to to interface to ATMega16U4 but keep getting : Device signature = 0x000000
I am using Avrdude command line and USBTiny ISP.
Can you please suggest some solution to this?
Below are the answer to the questions and the log (verbose) of what's going on.
1) Are you using a USBtiny from a kit or from DIY? Make sure you mention that in your post
From a kit.
2) What OS and computer are you using?
OSX
3) Which programming software are you using, and what chip?
AvrDude to ATMega16u4
4) Did the USBtinyISP ever work (even once) or is it your first time trying to talk to a chip
Yes it works fine with standard Arduino
Stpns-MacBook-Pro:HW stpn$ avrdude -C avrdude.conf -c usbtiny -p m16u4 -B 12 -F -v -v -v -v -v -v
avrdude: Version 5.11.1, compiled on Feb 12 2013 at 01:24:54
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "avrdude.conf"
         User configuration file is "/Users/stpn/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : unknown
         Using Programmer              : usbtiny
         Setting bit clk period        : 12.0
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 001:006-1781-0c9f-ff-00
         AVR Part                      : ATmega16U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no        512    8      0  9000  9000 0x00 0x00
             Memory Ops:
               Oeration     Inst Bit  Bit Type  Bitno  Value
               READ               31     VALUE      7      1
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      0
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23    IGNORE      7      0
                                  22    IGNORE      6      0
                                  21    IGNORE      5      0
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18   ADDRESS     10      0
                                  17   ADDRESS      9      0
                                  16   ADDRESS      8      0
                                  15   ADDRESS      7      0
                                  14   ADDRESS      6      0
                                  13   ADDRESS      5      0
                                  12   ADDRESS      4      0
                                  11   ADDRESS      3      0
                                  10   ADDRESS      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
               WRITE              31     VALUE      7      1
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      0
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23    IGNORE      7      0
                                  22    IGNORE      6      0
                                  21    IGNORE      5      0
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18   ADDRESS     10      0
                                  17   ADDRESS      9      0
                                  16   ADDRESS      8      0
                                  15   ADDRESS      7      0
                                  14   ADDRESS      6      0
                                  13   ADDRESS      5      0
                                  12   ADDRESS      4      0
                                  11   ADDRESS      3      0
                                  10   ADDRESS      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7     INPUT      7      0
                                   6     INPUT      6      0
                                   5     INPUT      5      0
                                   4     INPUT      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
               LOADPAGE_LO        31     VALUE      7      1
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      0
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      1
                                  23     VALUE      7      0
                                  22     VALUE      6      0
                                  21     VALUE      5      0
                                  20     VALUE      4      0
                                  19     VALUE      3      0
                                  18     VALUE      2      0
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15     VALUE      7      0
                                  14     VALUE      6      0
                                  13     VALUE      5      0
                                  12     VALUE      4      0
                                  11     VALUE      3      0
                                  10   ADDRESS      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7     INPUT      7      0
                                   6     INPUT      6      0
                                   5     INPUT      5      0
                                   4     INPUT      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
               WRITEPAGE          31     VALUE      7      1
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      0
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      1
                                  24     VALUE      0      0
                                  23     VALUE      7      0
                                  22     VALUE      6      0
                                  21    IGNORE      5      0
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18   ADDRESS     10      0
                                  17   ADDRESS      9      0
                                  16   ADDRESS      8      0
                                  15   ADDRESS      7      0
                                  14   ADDRESS      6      0
                                  13   ADDRESS      5      0
                                  12   ADDRESS      4      0
                                  11   ADDRESS      3      0
                                  10     VALUE      2      0
                                   9     VALUE      1      0
                                   8     VALUE      0      0
                                   7    IGNORE      7      0
                                   6    IGNORE      6      0
                                   5    IGNORE      5      0
                                   4    IGNORE      4      0
                                   3    IGNORE      3      0
                                   2    IGNORE      2      0
                                   1    IGNORE      1      0
                                   0    IGNORE      0      0
           flash         65     6   128    0 yes     16384  128    128  4500  4500 0x00 0x00
             Memory Ops:
               READ_LO            31     VALUE      7      0
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      0
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      0
                                  22   ADDRESS     14      0
                                  21   ADDRESS     13      0
                                  20   ADDRESS     12      0
                                  19   ADDRESS     11      0
                                  18   ADDRESS     10      0
                                  17   ADDRESS      9      0
                                  16   ADDRESS      8      0
                                  15   ADDRESS      7      0
                                  14   ADDRESS      6      0
                                  13   ADDRESS      5      0
                                  12   ADDRESS      4      0
                                  11   ADDRESS      3      0
                                  10   ADDRESS      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
               READ_HI            31     VALUE      7      0
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      0
                                  27     VALUE      3      1
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      0
                                  22   ADDRESS     14      0
                                  21   ADDRESS     13      0
                                  20   ADDRESS     12      0
                                  19   ADDRESS     11      0
                                  18   ADDRESS     10      0
                                  17   ADDRESS      9      0
                                  16   ADDRESS      8      0
                                  15   ADDRESS      7      0
                                  14   ADDRESS      6      0
                                  13   ADDRESS      5      0
                                  12   ADDRESS      4      0
                                  11   ADDRESS      3      0
                                  10   ADDRESS      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
               LOADPAGE_LO        31     VALUE      7      0
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      0
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23    IGNORE      7      0
                                  22    IGNORE      6      0
                                  21    IGNORE      5      0
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18    IGNORE      2      0
                                  17    IGNORE      1      0
                                  16    IGNORE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13   ADDRESS      5      0
                                  12   ADDRESS      4      0
                                  11   ADDRESS      3      0
                                  10   ADDRESS      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7     INPUT      7      0
                                   6     INPUT      6      0
                                   5     INPUT      5      0
                                   4     INPUT      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
               LOADPAGE_HI        31     VALUE      7      0
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      0
                                  27     VALUE      3      1
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23    IGNORE      7      0
                                  22    IGNORE      6      0
                                  21    IGNORE      5      0
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18    IGNORE      2      0
                                  17    IGNORE      1      0
                                  16    IGNORE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13   ADDRESS      5      0
                                  12   ADDRESS      4      0
                                  11   ADDRESS      3      0
                                  10   ADDRESS      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7     INPUT      7      0
                                   6     INPUT      6      0
                                   5     INPUT      5      0
                                   4     INPUT      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
               WRITEPAGE          31     VALUE      7      0
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      0
                                  27     VALUE      3      1
                                  26     VALUE      2      1
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23   ADDRESS     15      0
                                  22   ADDRESS     14      0
                                  21   ADDRESS     13      0
                                  20   ADDRESS     12      0
                                  19   ADDRESS     11      0
                                  18   ADDRESS     10      0
                                  17   ADDRESS      9      0
                                  16   ADDRESS      8      0
                                  15   ADDRESS      7      0
                                  14   ADDRESS      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7    IGNORE      7      0
                                   6    IGNORE      6      0
                                   5    IGNORE      5      0
                                   4    IGNORE      4      0
                                   3    IGNORE      3      0
                                   2    IGNORE      2      0
                                   1    IGNORE      1      0
                                   0    IGNORE      0      0
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
             Memory Ops:
               READ               31     VALUE      7      0
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      1
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      0
                                  22     VALUE      6      0
                                  21     VALUE      5      0
                                  20     VALUE      4      0
                                  19     VALUE      3      0
                                  18     VALUE      2      0
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
               WRITE              31     VALUE      7      1
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      0
                                  27     VALUE      3      1
                                  26     VALUE      2      1
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      1
                                  22     VALUE      6      0
                                  21     VALUE      5      1
                                  20     VALUE      4      0
                                  19     VALUE      3      0
                                  18     VALUE      2      0
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7     INPUT      7      0
                                   6     INPUT      6      0
                                   5     INPUT      5      0
                                   4     INPUT      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
             Memory Ops:
               READ               31     VALUE      7      0
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      1
                                  27     VALUE      3      1
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      0
                                  22     VALUE      6      0
                                  21     VALUE      5      0
                                  20     VALUE      4      0
                                  19     VALUE      3      1
                                  18     VALUE      2      0
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
               WRITE              31     VALUE      7      1
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      0
                                  27     VALUE      3      1
                                  26     VALUE      2      1
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      1
                                  22     VALUE      6      0
                                  21     VALUE      5      1
                                  20     VALUE      4      0
                                  19     VALUE      3      1
                                  18     VALUE      2      0
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7     INPUT      7      0
                                   6     INPUT      6      0
                                   5     INPUT      5      0
                                   4     INPUT      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
             Memory Ops:
               READ               31     VALUE      7      0
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      1
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      0
                                  22     VALUE      6      0
                                  21     VALUE      5      0
                                  20     VALUE      4      0
                                  19     VALUE      3      1
                                  18     VALUE      2      0
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
               WRITE              31     VALUE      7      1
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      0
                                  27     VALUE      3      1
                                  26     VALUE      2      1
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      1
                                  22     VALUE      6      0
                                  21     VALUE      5      1
                                  20     VALUE      4      0
                                  19     VALUE      3      0
                                  18     VALUE      2      1
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7    IGNORE      7      0
                                   6    IGNORE      6      0
                                   5    IGNORE      5      0
                                   4    IGNORE      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
             Memory Ops:
               READ               31     VALUE      7      0
                                  30     VALUE      6      1
                                  29     VALUE      5      0
                                  28     VALUE      4      1
                                  27     VALUE      3      1
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      0
                                  22     VALUE      6      0
                                  21     VALUE      5      0
                                  20     VALUE      4      0
                                  19     VALUE      3      0
                                  18     VALUE      2      0
                                  17     VALUE      1      0
                                  16     VALUE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7    IGNORE      7      0
                                   6    IGNORE      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
               WRITE              31     VALUE      7      1
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      0
                                  27     VALUE      3      1
                                  26     VALUE      2      1
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23     VALUE      7      1
                                  22     VALUE      6      1
                                  21     VALUE      5      1
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18    IGNORE      2      0
                                  17    IGNORE      1      0
                                  16    IGNORE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9    IGNORE      1      0
                                   8    IGNORE      0      0
                                   7     VALUE      7      1
                                   6     VALUE      6      1
                                   5     INPUT      5      0
                                   4     INPUT      4      0
                                   3     INPUT      3      0
                                   2     INPUT      2      0
                                   1     INPUT      1      0
                                   0     INPUT      0      0
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
             Memory Ops:
               READ               31     VALUE      7      0
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      1
                                  27     VALUE      3      1
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23    IGNORE      7      0
                                  22    IGNORE      6      0
                                  21    IGNORE      5      0
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18    IGNORE      2      0
                                  17    IGNORE      1      0
                                  16    IGNORE      0      0
                                  15     VALUE      7      0
                                  14     VALUE      6      0
                                  13     VALUE      5      0
                                  12     VALUE      4      0
                                  11     VALUE      3      0
                                  10     VALUE      2      0
                                   9     VALUE      1      0
                                   8     VALUE      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Memory Ops:
               READ               31     VALUE      7      0
                                  30     VALUE      6      0
                                  29     VALUE      5      1
                                  28     VALUE      4      1
                                  27     VALUE      3      0
                                  26     VALUE      2      0
                                  25     VALUE      1      0
                                  24     VALUE      0      0
                                  23    IGNORE      7      0
                                  22    IGNORE      6      0
                                  21    IGNORE      5      0
                                  20    IGNORE      4      0
                                  19    IGNORE      3      0
                                  18    IGNORE      2      0
                                  17    IGNORE      1      0
                                  16    IGNORE      0      0
                                  15    IGNORE      7      0
                                  14    IGNORE      6      0
                                  13    IGNORE      5      0
                                  12    IGNORE      4      0
                                  11    IGNORE      3      0
                                  10    IGNORE      2      0
                                   9   ADDRESS      1      0
                                   8   ADDRESS      0      0
                                   7    OUTPUT      7      0
                                   6    OUTPUT      6      0
                                   5    OUTPUT      5      0
                                   4    OUTPUT      4      0
                                   3    OUTPUT      3      0
                                   2    OUTPUT      2      0
                                   1    OUTPUT      1      0
                                   0    OUTPUT      0      0
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Setting SCK period to 12 usec
CMD: [ac 53 00 00] [ff ff ff ff]
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATmega16U4 is 1E 94 88
avrdude done.  Thank you.
Stpn
Re: Device signature = 0x000000 from Avrdude to ATMega16u4
by adafruit_support_rick on Wed Mar 06, 2013 12:09 pm
The USBtiny is unable to communicate with the chip. How are you connected to the chip? How is the chip being powered? Does the chip have a crystal or other clock source connected?
by Stpn on Wed Mar 06, 2013 1:51 pm
driverblock wrote:The USBtiny is unable to communicate with the chip. How are you connected to the chip? How is the chip being powered? Does the chip have a crystal or other clock source connected?
Hi! We're connecting to the chip via ISP (6 pin to 6 pin). The chip is powered via external power supply (5V). The chip has external 16Mhz clock. Please let me know if that clarifies that. Thank you.
Stpn
by adafruit_support_rick on Wed Mar 06, 2013 3:07 pm
Do you have the ICSP socket oriented correctly? Red wire to pin 1?
Make sure you have electrically secure connections from the ICSP header to the chip. If your on a breadboard, try different holes. Make sure the gauge of your jumper wires is heavy enough to make a solid breadboard connection.
If you post some clear, detailed pictures, we can take a look
