Finger print sensor Library
by ratheeshbr on Fri Mar 08, 2013 7:51 pm
I am using adafruit/Adafruit-Fingerprint-Sensor-Library for interfacing with arduino. I am getting an ID in which I have stored the template from the scanner. Is it possible to get a value representing the image taken by the scanner? I am having two finger print scanners and I have to get the same value out for the same finger from both sensors. Is it possible to get?
ratheeshbr
Re: Finger print sensor Library
by adafruit_support_rick on Fri Mar 08, 2013 9:17 pm
I'm not sure I understand the question. Can't you simply use the same ID when enrolling the finger on each sensor?
by ratheeshbr on Fri Mar 08, 2013 9:21 pm
No,
In this project the second sensor is in a different module and what I want is to write the specific code obtained from the first finger print scanner to smart card and it should match with the output from the second sensor.
Is it possible?
ratheeshbr
by adafruit_support_rick on Fri Mar 08, 2013 9:50 pm
The ID number that you get back from reading a fingerprint is a number that you enter when you enroll the finger.
You're going to have to enroll each finger on each sensor separately. Just use the same ID number on each sensor.
by ratheeshbr on Tue Mar 12, 2013 7:58 pm
The second sensor will be at a common place so that there will not be a database . I want to write the code generated from the first finger to a smart card and as a proof of this smart card not being used by another person, I want the same code generated from the second finger print also.
Is is possible sir?
ratheeshbr
by adafruit_support_rick on Wed Mar 13, 2013 10:40 am
There is no central database for these things. It's all internal to the unit. You show it a finger and assign an ID. That's called 'enrolling'. You have to repeat this process for each sensor you plan to use.
Every person you authorize will have to be enrolled twice - once at each sensor. Assign them the same ID at both sensors.
by ratheeshbr on Wed Mar 13, 2013 1:44 pm
Thnx for the reply
ratheeshbr
cron
