OurLink USB WiFi - Product 1012
by dhamultun on Wed Mar 13, 2013 9:01 pm
I recently purchased the USB WiFi Module and have be using it fine with RBMC. Was easy setup in RBMC, but I am having difficulty getting it to work with Occidentalis v0.2. On boot-up it gets to DHCPDISCOVER keeps trying wlan0 on port 67 interval 4 then 11 etc...It finally fails and says "No DHCPOFFERS"
I also do not have the WiFi GUI on mine, not sure why. I manually configured by entering my SSID and PW, but it is not working. The issue is at boot and I do not know what I should try next. Any help appreciated.
Going to try connecting to wired LAN and update for now, just in case...
http://www.adafruit.com/products/1012
dhamultun
Re: OurLink USB WiFi - Product 1012
by adafruit_support_rick on Thu Mar 14, 2013 10:41 am
dhamultun wrote:It finally fails and says "No DHCPOFFERS"
Do you have SSID broadcast enabled on your router? You will see this error if broadcast is turned off.
by dhamultun on Thu Mar 14, 2013 8:17 pm
SSID is set to broadcast. I've tried everything I can think of, even downloaded the distro again and started from scratch...same results. Going to try the latest wheezy from the RaspPi downloads and see what happens.
dhamultun
by dhamultun on Thu Mar 14, 2013 8:35 pm
Just installed the latest version of wheezy and WiFi worked straight out of the box! Must be something wrong with occidentalis v0.2. Might try it again some other time.
dhamultun
by wildtang3nt on Fri Mar 15, 2013 1:51 am
Occidentalis is getting a tad bit outdated. If I knew how they compiled their kernel I'd be tempted to roll my own unofficial v0.3
Proud owner of (among other wonderful things):
Li-Poly MintyBoost
RGB LCD Pi Plate & Pi Dish
Ice Tube Clock & USBTinyISP
wildtang3nt
by adafruit_support_rick on Fri Mar 15, 2013 2:11 pm
Weird - mine works just fine in occidentalis 0.2
by dhamultun on Sat Mar 16, 2013 6:08 pm
Decided to install any kernel modules that I may need manually. Gives me a good excuse to learn more about using Linux. So far so good!
dhamultun
